How hot do headers get?
Old Apr 17, 2002 | 11:08 PM
xfactor974's Avatar
xfactor974
Default How hot do headers get?
I'm buying sleeve for the lines and I need to know how hot the headers will get on my engine about 1" away from them. Anyone have this valuable info?
Old Apr 17, 2002 | 11:21 PM
Jvette73's Avatar
Jvette73
Default Re: How hot do headers get? (xfactor974)
Dont know the specific temp but on a hot night of hard runnin, they can glow cherry red. Mine have done it before.
Old Apr 18, 2002 | 12:10 AM
killain's Avatar
killain
Oldtimer
It can run up to 400 to 500 degrees if you were running a steady 65 MPH.
Old Apr 18, 2002 | 12:58 AM
flynhi's Avatar
flynhi
I measured the temps on my ceramic coated headers a while back using an infrared gun type thermometer. Singles were in the 550 range; the pair at 3/5 and 4/6 were around 675. This was after normal driving and while idling. Ambient temp was about 85.
[Modified by flynhi, 4:18 PM 4/18/2002]
Old Apr 18, 2002 | 01:06 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
JetHot ceramic coating is supposed to withstand 1300 degree temps, several people have burned the coating off their headers by either a very lean condition or badly miss timed. This usually happens at first startup when guys are trying to break in a new cam. Like one of the other guys said they can get hot enough to glow if you run your car hard enough, but under most usual conditions a well tuned car's headers shouldn't get over 1000 degrees.
Old Apr 18, 2002 | 09:02 AM
norvalwilhelm's Avatar
norvalwilhelm
I don't know what temperatures the pipes are but exhaust gas temperature measured with a probe in the header pipe right out of the engine is around 1300 degree F. It can under lean conditions go to 1400F. Under hard runs the pipes do glow.
Old Apr 18, 2002 | 09:15 AM
ram82fire's Avatar
ram82fire
Default Re: How hot do headers get? (norvalwilhelm)
I have found temps to be very close to Norvals findings . I used the probes in individual runners for testing purposes and got readings of 900f light cruise and close to 1300f under load. The testing was done on a 427 side oiler with dual quads .
Geo :rolleyes:
Old Apr 18, 2002 | 10:25 AM
xfactor974's Avatar
xfactor974
Default Re: How hot do headers get? (ram82fire)
So what would you guys estimate the temp at 1" away from the headers. My fuel line and trans lines are very close to the headers, maybe 2" away and I'm looking to buy sleeving from McMaster for them. Do you think 500 deg rated stuff is enough or should I go higher?
Old Apr 18, 2002 | 10:31 AM
Fevre's Avatar
Fevre
Along that lines, what about plug wire boot covers? I melted a couple of my boots when I broke in my cam, ran it lean for a about 5 minutes and noticed the manifolds end and exhaust pipes were glowing red. Shut it down and rejetted higher which made the glowing go down alot. Are those temp mentioned above with bare or painted headers as opposed to wrapped or coated headers. Norval I noticed you have yours wrapped not coated or do you have both?
Old Apr 18, 2002 | 11:08 AM
norvalwilhelm
Default Re: How hot do headers get? (Fevre)
My headers are wrapped. I really like the fact that after a hard run and you open the hood that heat wave doesn't hit you. I found the underhood temperatures really went down after wrapping. My wrap is close to 10 years old but don't remember for sure and it is still in good shape. I do not take long high speed cruises.
The temperature of 1300F is not the header temperature but the exhuast gas exiting the head about 1 inch out. This is read off a probe inserted into the head and read off a temp gage in the car while running hard. It can be used to check for rich lean conditions. Some race cars have 8 probes and 8 gages on the dash to watch out for lean conditions. 1400F is definitely lean.
Old Apr 18, 2002 | 11:11 AM
Fevre's Avatar
Fevre
As always, good info
thanks
Old Apr 18, 2002 | 11:35 AM
fontking1a's Avatar
fontking1a
You can fry an egg on them....hot enough?
Old Apr 18, 2002 | 05:55 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I would go with something rated greater than 500 F. Metal temps are typically 1/2 the temp of the exhaust gas and running something that close to the pipes will probably expose it to temps over 500. Especially if there isn't a lot of airflow around that particular area.
Old Apr 18, 2002 | 10:34 PM
xfactor974's Avatar
xfactor974
Default Re: How hot do headers get? (burners)
I bought some silica sleeve rated for 2300 deg for the fuel lines and the trans lines. it was only 2.13 per foot from McMaster as opposed to 3x that for fyrejacket from Fel-pro
Old Nov 15, 2015 | 08:31 AM
AdamMeh's Avatar
AdamMeh
At idle in the garage, our ceramic coated headers run about 360f on the single tubes (small block). The center tubes run about 450. This is measuring with a IR gun about 2" - 3" from the tubes.
Old Nov 15, 2015 | 09:03 AM
76Rat's Avatar
76Rat
I hate to break it to you, but this thread is over 13 years old.
Old Nov 15, 2015 | 09:29 AM
jb78L-82's Avatar
jb78L-82
Bingo...Exactly what I have measured with my infrared on my shorty's on the 78 and BBK shorty's on my 94 Mustang GT 5.0....Off highway around 350-400 degrees...both are ceramic coated....
To How hot do headers get?
Old Nov 15, 2015 | 09:34 AM
redvetracr's Avatar
redvetracr
buy a product from Aeroquip called "Fire sleeve", I use it on my car below
Old Nov 15, 2015 | 09:35 AM
toobroketoretire's Avatar
toobroketoretire
About 1250 degrees at wide open throttle...................
Old Nov 15, 2015 | 10:43 AM
AdamMeh's Avatar
AdamMeh
DOH! lol wonder how it came up in the list today?
Oh well, maybe this info will help someone down the road.
