CENTERFORCE CLUTCHES
Old Apr 18, 2002 | 11:01 AM
Ken74Conv's Avatar
Ken74Conv
Default CENTERFORCE CLUTCHES
Is anyone running a "Centerforce clutch"?
Which one?
How do you like it.
I'm looking for a good clutch at a reasonable price to put behind the
ZZ4 I'm about to install.
Old Apr 18, 2002 | 11:04 AM
Fevre's Avatar
Fevre
Default Re: CENTERFORCE CLUTCHES (Ken74Conv)
I've got the dual force (think that is the name) and not sure how I feel about it. It grips well but it feels like it grinds or binds alot when I engage the clutch. It comes and goes so I am going to live with it. I'll deal with it if it gets real bad or wait till I put my 383 back in next year. Sorry I couldn't give a definitive answer.
Old Apr 18, 2002 | 11:20 AM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: CENTERFORCE CLUTCHES (Fevre)
I'm using their clutch #384148. It's not the dual friction, it's just their standard clutch, pressure plate # 165552. I really like it, but I'm not doing burn outs.
Old Apr 18, 2002 | 11:34 AM
fontking1a's Avatar
fontking1a
Centerforce makes a great product...no problems here.
Old Apr 18, 2002 | 11:39 AM
Keith1979's Avatar
Keith1979
Default Re: CENTERFORCE CLUTCHES (fontking1a)
i like myn very well, its the dual friction and it grabs very nice, peddle isnt hard to push in either :)
Old Apr 18, 2002 | 11:41 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Paul,
As most who have followed any of my posts know, I'm a huge proponent of using GM parts, but Centerforce really does make a good clutch. Much less pedal pressure than the original GM unit and superior clamping force.
I agree with your decision to use the standard Centerforce clutch. I have two currently installed (and two more that will be installed) behind some pretty stout engines and I can tell you that the standard unit has no problem with 500 horsepower big block. The dual friction model may be the hot ticket for the serious drag car (on slicks) or one with an engine far in excess of what most of us run on the street, but it is pretty much overkill for most of us.
While Centerforce offers their own throwout bearing, I prefer to use the GM part as I feel it is of better quality.
Regards,
Old Apr 18, 2002 | 11:44 AM
Fevre's Avatar
Fevre
Default Re: CENTERFORCE CLUTCHES (Rowdy Rat)
Overkill is how these companies make there money on idiots like me! :bb
Any ideas what could be causing the clutch binding/grinding I am experiencing? Feels like the throw out bearing and the pressure plate not like to kiss.
Old Apr 18, 2002 | 11:58 AM
john73bb's Avatar
john73bb
I have the dual friction and like it a lot. I really appreciated the lower pedal pressure - that made a big difference in driveability. It grips just fine, and never chatters.
Old Apr 18, 2002 | 01:20 PM
SteveG75's Avatar
SteveG75
Default Re: CENTERFORCE CLUTCHES (john73bb)
Same, same.
Old Apr 18, 2002 | 01:34 PM
Mack's Avatar
Mack
Me, too... behind a ZZ4... Great clutch.
Old Apr 18, 2002 | 02:28 PM
Gordonm's Avatar
Gordonm
Default Re: CENTERFORCE CLUTCHES (Mack76)
i have the standard Centerforce behind my car it it is great. I have drag raced it plenty and it holds everything I throw at it. Have not run sticky tires but I'm not afraid to either with this clutch.
Old Apr 18, 2002 | 03:08 PM
Ken74Conv's Avatar
Ken74Conv
Default Re: CENTERFORCE CLUTCHES (Gordonm)
I'm convinced.
Thanks to everybody for their help!!!
:cheers:
Old Apr 18, 2002 | 11:26 PM
Darkness's Avatar
Darkness
I use the standard one on a 405hp LT-5 and it's has never sliped and pedal is as light as the throtle, the dual friction would be a waist of money.:nono:
Paul
Old Apr 18, 2002 | 11:30 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: CENTERFORCE CLUTCHES (inferno-vette)
i just installed a centerforce dual friction clutch in 74vettes car and he likes it just trying to get used to the grabbing force it has.
Old Apr 19, 2002 | 12:00 AM
73 LS-4's Avatar
73 LS-4
I have the dual friction on mine, probably overkill but that's better then underkill, probably could have gone a step down but too late now. Works great, pedal effort is about the same as stock. I do have a friend however that had problems with his, causing a bad vibration becouse the weights shifted on it, but this seems to be uncommon.
:cheers:
Pat Kunz
Old Apr 19, 2002 | 01:17 AM
Bob Jenkins's Avatar
Bob Jenkins
I have the Ceterforce Dual Friction unit and it has worked perfectly over the past few years. Easy pedal pressure and hooks-up hard....no slipping or and kind of vibrations :smash: :chevy
To CENTERFORCE CLUTCHES
