Installing Cylinder heads
Old Apr 18, 2011 | 07:37 PM
socal79's Avatar
socal79
Default Installing Cylinder heads
hey all I am going to try and install my cylinder heads this weekend. I have done the procedure in school before but the only thing I am not sure about is which bolts go in to the water jacket and require teflon sealant? anyone know the answer to this?
Old Apr 18, 2011 | 09:13 PM
Oldguard 7's Avatar
Oldguard 7
All of them.
Old Apr 18, 2011 | 09:15 PM
Ghunt's Avatar
Ghunt
It wont hurt to use sealant on all of them. Do it wright the first time, you dont want to redo it.
Geo
Old Apr 18, 2011 | 09:16 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yep I put Permatex #2 on all of them, don't have a clue which ones go through
Old Apr 18, 2011 | 09:28 PM
jaycall88's Avatar
jaycall88
Hello,
Most the information I get is off the internet and youtube to get a visual on how things are installed. After that I go to this forum for verification before I do anything.
This video might be helpful!
http://www.youtube.com/watch?v=WVxs07ym-ic
Old Apr 18, 2011 | 11:30 PM
Tim81's Avatar
Tim81
Play it safe and put some type of sealant on all of the bolts. I use permatex #2...
Old Apr 19, 2011 | 01:44 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Yes I do the same thing.
Old Apr 19, 2011 | 08:30 AM
Indiancreek's Avatar
Indiancreek
If you really want to know, use one of the hand vacume pumps and pull a vacume on each bolt hole. The drilled through holes won't hold a vacume.
I seal the drill through holes.
Old Apr 19, 2011 | 12:18 PM
69 Chevy's Avatar
69 Chevy
Non-hardening Permatex #2 has been used in this application for decades. I was told way back when, that the reason to coat all head bolt threads whether they go into the water jacket or not, is to get uniform pull when they are torqued. It sure sounded reasonable.
Old Apr 19, 2011 | 01:48 PM
socal79's Avatar
socal79
thanks everyone for the advice it is very helpful I cant wait to throw these heads on!
Old Apr 19, 2011 | 02:00 PM
redman76's Avatar
redman76
St. Jude Donor '09
What are you putting on? Are you changing cam too?
Old Apr 21, 2011 | 02:28 AM
socal79's Avatar
socal79
I am putting on some Procomp Heads that were CnCed by RPM Motorsports in santa clarita. The bottom end is a 383 with a 268xe comp cam
To Installing Cylinder heads
