so this is the 3rd time i have tried to start my vette and its started to smoke near the igition. i just bought a new ignition but cant figure out how to get the column off to change it. please let me know if u can help!
Alright pops..is it a tilt column? If its a non tilt its a fairly easy project..question two..did you buy the key ignition or the ignition switch..the switch is located at the bottom of the column..the key..well I hope you know where that is! Sounds like you have a short or ground issue..does the car start if it smokes??.. and does it smell like burning plastic?? I hate to say get your head down by the pedals and look at the wiring at the ignition switch..look for melted wires..yuck..
