SR111 tube frame
Old Feb 4, 2012 | 02:22 AM
  #41
Gale Banks 80''s Avatar
Gale Banks 80'
Originally Posted by vetteguy22
Hi Gale Banks 80', Thanks for the heads up. I thought the stock 255/60/15 was about the same height as the 315 and yes the C4 suspension is quit a bit wider than the C3. I made my decision on the tires size after talking with Mike at SRIII and seeing the 1981? that he did the same thing to. If you check out his web site there is a god pic of it.
I'm going to take a stab at the pictures and say they are 18" 315's and not 17's. With 18's larger Diameter Tires are avalable. I don't know if Aftrmarket Wheels are in Your Plane or C4's. If You really need 17's or not. Some people are running both, 17 up front an 18 out back. If You Search Fender Flare here on the site You will find lots of Picks and opions of what works and what dosn't.
Old Feb 4, 2012 | 10:12 AM
  #42
spedaleden's Avatar
spedaleden
The company is an hour away from where I live. I am going to see them and thinking of going this route with my C3.
Old Feb 4, 2012 | 10:30 AM
  #43
holley505's Avatar
holley505
Originally Posted by 69427
Exactly how much do you think the stock frame and suspension weighs?
900-1,000 lbs... guessing.
Old Feb 4, 2012 | 11:04 AM
  #44
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by Shark Racer
Sorry, I misread the quoting thread. Guy you quoted referred to C5 diffs and for some reason I thought he was talking about C6 diffs when he mentioned LS7.
I appreciate that, comes from a class act, hardly ever hear anyone say "sorry" they would rather fall on their swords first
Old Feb 4, 2012 | 05:22 PM
  #45
vetteguy22's Avatar
vetteguy22
I checked with the builder, Mike at SRIII, and verified that the fronts are P275/40ZR17 on 91/2" wheels and the backs are P315/35ZR17 on 11 1/2" wheels. The size as the stock C4 ZR1.
Old Feb 4, 2012 | 08:08 PM
  #46
3JsVette's Avatar
3JsVette
That tire and wheel combination will work fine IF you get the wheels and tires that you want with the backspacing you want and fit the flares to the wheel/tire combo. If you search you will see that the flares have to be "worked" to cover the tire and get the look you want. The L88 flares where made to cover taller tires than the 17" diameter wheels (or bigger) we currently run on these C3s. Also the flare as it comes out of the mold has a large gap behind the tire unless it's modified. If you mount the wheels and tires on the car 1st and install the flares after you can "position" the flares to get the "look" you are after. Some guys like the tire at the edge of the flare some guys like the tire "tucked in" a little. Ride height and suspension travel should also be considered. It looks great when the tire is at the edge of the flare and the top of the tire is even with the wheel opening but what happens when you hit the 1st bump? The 17s in the sizes you're looking out will provide the performance you're looking for and will look great doing it if you position the flares to your combination rather than installing the flares and then trying to fill the wheel wells.
Good luck with your project. You need to start a build thread and post pictures of your progress.
Old Feb 4, 2012 | 08:48 PM
  #47
vetteguy22's Avatar
vetteguy22
Thanks for the encouragement 3JsVette. I was planning to set the body on the chassis prior to installing the flares. I agree, it would be much easier to make the flares fit the setup rather than try to make the tires fit the flares. I am hoping to post some pics this weekend if time allows. Have to service three vehicles this weekend before I can play. Work first, otherwise can't afford to play.
Old Feb 7, 2012 | 11:24 AM
  #48
vetteguy22's Avatar
vetteguy22
Hi Guys, Well here goes, I'm going to try and post some pics of the project.
Old Feb 7, 2012 | 02:27 PM
  #49
ZBRA's Avatar
ZBRA
Old Feb 7, 2012 | 06:30 PM
  #50
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Wow, that thing is going to draw some well-deserved attention.
Keep the pics coming; looks like a fun build.
Old Feb 7, 2012 | 06:55 PM
  #51
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Awsome car **** dude!!!! Looks hot!!!
Old Feb 9, 2012 | 12:46 AM
  #52
vetteguy22's Avatar
vetteguy22
Thanks for the good words guys, I appreciate it. It has been a lot of fun so far. I'm trying to get the fuel lines done this week, then on to the brake lines. Hopefully soon after that I can transfer the body over and start on the body work (L88 flares and hood scoop). I' post more pics as the project progresses.
Rob
