Tach repair help
Old Apr 27, 2011 | 12:31 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Tally Ho
The PC board is new from you. I'll try the hard wire next, possibly tonight if the weather is good. I don't like working during thunderstorms.
Yeah, I missed that. So we know the washers will not be an issue.
Let me know what you find out, we've been getting hammered too. Flood gates are going in today.
Willcox
Old Apr 27, 2011 | 03:08 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Willcox
I'll keep you and everyone updated. I sure appreciate everyone's inputs. This car has been a challenge of course I may be too much of a perfectionist. The average Joe would be driving the wheels off of it.
My thoughts are with all of you in the midwest and upper southeast. You guys have been getting hammered with foul weather. No rain here yet but the wind has been relentless and the humidity's off the scale. I expect the t-storms to roll in this evening.
Old Apr 27, 2011 | 03:41 PM
0Willcox Corvette
Former Vendor
Originally Posted by puzzigully
Wilcox,
are you saying that when you turn the ignition key to "on" the tach should read zero before starting?
I think i have a problem with my tach (a US shop replaced the circuit board for me) in that it sits below zero when at idle, but seems to increase faster than the engine does..
looking at your video, it seems as though I need to set my zero and adjust the potentiometer using your signal generator...
sorry for the Hi-jack....
Yes, you must power up the tach with 12 volts and ground and re-set the needle. You can use your own car to set the rpm's by if you have a old Actron Dwell meter. You can read the RPMs on this and set the tach at the same time.
Willcox
Old Apr 27, 2011 | 06:47 PM
puzzigully's Avatar
puzzigully
Wilcox,
thanks for the help - I can probably set the zero without having to take out the tach unit, just the plastic cover, correct?
then check the rpm on motor vs tach and if that reads incorrect, I'll have to remove the unit and adjust the "pot" - am I on the right track?
Old Apr 27, 2011 | 10:53 PM
0Willcox Corvette
Former Vendor
Wilcox,
Yes. this is correct but I've never done a zero set in the car..
You should watch the video if you have not done so...
Old Apr 27, 2011 | 11:35 PM
puzzigully's Avatar
puzzigully
Cheers for that.
Have watched the video - VERY helpful.
Old Apr 28, 2011 | 09:43 AM
Red 69's Avatar
Red 69
I will make this real simple, as I had this problem and tried most of the things mentioned in this thread. I live near Ecklers, so I had their tech guys and convenience of returning parts that they readily accepted. I replaced my tach filter, then replaced about four different circuit boards from Ecklers with no help. My 79 tach needle worked, but bounced around and when it held steady, it seemed to be double the RPM's it should have read.
In the end, I bought a tach and circuit board unit from an 80 L48 model by a forum member. It only cost me $30 and bingo, I had a tach that worked perfectly. It didn't have the L82 logo and redline, but it worked flawlessly. You might consider going this route. You want a tach and circuit from the same car that was working. Don't mix boards and tachs, they aren't all the same, or so they tell me.
Old Apr 28, 2011 | 07:24 PM
puzzigully's Avatar
puzzigully
Red 69,
I also bought the replacement from Ecklers as the original was not working (Did not know about Wilcox at the time).
I need to convince myself it is correctly set up before I blame the circuit board, but at idle the needle sits below zero (off the scale), a slight blip of the gas sees it shoot up to 1000rpm, or something more believable.
The Tachometer needle is quite steady almost all the time, so I do not have that issue.
During driving, I'd say the needle climbs faster than what the engine noise would tend to indicate - but without a dwell meter or external tacho that I know is accurate, i cannot say with 100% confidence how far out it is.
I do know it isn't 100% right, but how far out is unknown right now.
Willcox - you say you can adjust the resistor on the board to change the Tachometer's behavior. Is this just a scaling adjustment?
Old Apr 28, 2011 | 10:18 PM
0Willcox Corvette
Former Vendor
The boards are not the same that is for sure. The pot we used on our board is a 15 turn pot.. and you have to physically turn the thing to make a change. Other boards have a 1 turn pot on them and you can tap it with your finger and the adjustment will change.
Now one thing that has not be crossed is the analog movement. Yes they do go bad. Is this normal.. No.. but it does happen from time to time.
I don't know where Ecklers gets their boards but if it came from us it will have Willcox on the board. We did this to avoid any confusion as to the boards origin.
The difference in the 1978-79 board and the 1980-1982 board is the calibration.. if you look at the faces they are not the same.
Red.. if you want to sell the extra tach I'd be a buyer.. mainly because I need cores.
Puzzi-
If a zero set is not done correctly the tach will be off at all points. Yes you can adjust our boards and they are as accurate as the original GM boards. (the video of the 1978-1982 shows this)... Our board was actually a bit closer in readings.
But.. to both of you and anyone reading this... If you want the tach tested and/or calibrated to match.. mail it to us.. This is a free service that we offer! Only cost is the return shipping.. If anyone wants to do this.. and I don't care where the board came from.. just call sales and get a RA number for the shop before you mail.
Willcox
Old Apr 28, 2011 | 10:29 PM
puzzigully's Avatar
puzzigully
Willcox,
i wish I'd known about you before i bought these parts! You seem so helpful.
I actually rang Ecklers to ask them for their advice on their part - the girl seemed to be taking while to find the info on installation/calibration. When she came back she referred me to a Youtube page - which was YOUR video!!
I had a look on your page and theirs and the circuit boards look almost exactly the same to the one in your installation instructions, but different to the one now showing as the new part available from you.
Maybe earlier ones were from the same supplier?
I might take you up on your offer of free calibration!!
Old Apr 28, 2011 | 11:02 PM
Red 69's Avatar
Red 69
I live in Ecklers neighborhood and I'd say forget about asking for advice. Most folks who answer the phone don't know answers to technical questions. I was in their showroom and we couldn't come up with a solution to my faulty tach. I was in and out five times changing parts in an effort to find what was wrong, to no avail.
WILLCOX The boards are not the same that is for sure. The pot we used on our board is a 15 turn pot.. and you have to physically turn the thing to make a change. Other boards have a 1 turn pot on them and you can tap it with your finger and the adjustment will change.
I tried to adjust one of the new boards with no result.
Finally, after much frustration I took a forum member up on his offer to sell me a tach and board he had in storage. As I said, that was my solution.
WILLCOX Red.. if you want to sell the extra tach I'd be a buyer.. mainly because I need cores.
I am going to hold the L-82 tach for possible future repair. Thanks for the info you have posted, it is nice to have a pro's offering advice.
Old Apr 29, 2011 | 02:51 PM
0Willcox Corvette
Former Vendor
No problem and thank you... The board they carry is not our board. Not sure why they have not picked this item up they go purchase the other boards we make for the late model cars.
Willcox
Old May 3, 2011 | 05:07 AM
  #33
puzzigully's Avatar
puzzigully
Wilcox,
I do have a quick question re Tach "Zero-ing"
Your vid shows you "tap" the needle onto the shaft.
The question is do you:
1. pull off the needle then re-attach it onto the shaft so it shows zero or
2. Can rotate the needle whilst it is on the shaft to zero with no need to remove the needle at all
Old May 3, 2011 | 01:50 PM
  #34
0Willcox Corvette
Former Vendor
To do a zero set:
You must have power and ground going to the tachometer. This powers it up but with no input (0). Before you put the needle back on, (make sure as the video shows) that the spindle is not pulled outward with the back side of your finger nail.
When you sit the needle back on the tach you don't want to press it, you want the needle to be barely sitting on the spindle allowing it to rotate on the shaft.
To make it rotate gently bump it with your finger until you hit zero and only then do you tap it with your finger to snug it up. It may take you a couple of times to get this right.
Willcox Inc.
Old May 5, 2011 | 09:15 PM
  #35
puzzigully's Avatar
puzzigully
Wilcox,
thanks, maybe I'm a bit slow to pick up what you're saying - but if I do understand, you want to fit the needle to the shaft ONLY when it is pointing to Zero.
You DO NOT want to have the needle firmly on the shaft, THEN have to move it to zero (turning the shaft at the same time)
Have I got that right?
Old May 5, 2011 | 10:57 PM
  #36
0Willcox Corvette
Former Vendor
Wilcox,
You put the needle on and do not press or push it down.. there will be some friction... but then you gently tap it to zero while powered up with no signal. Once you have it on zero you tap it with your finger and it should press on the shaft at or close to zero... If this fails.. you do it again..
Check out the video and you should see how I did it.
Willcox
Old May 8, 2011 | 07:34 PM
  #37
puzzigully's Avatar
puzzigully
Wilcox,
did the Zero in the car, a bit difficult since it was getting dark and bit hard to see - I guess I should have got a lead light!!
Anyway, 1st go got it within 100rpm on the low side, next try was 50rpm on the high side, next was 50rpm on the low side.
Funny thing was that when I kept checking the needle seemed to be high by 50rpm
I will probably be happy with that as it is..
To Tach repair help
Old May 8, 2011 | 10:13 PM
  #38
Red 69's Avatar
Red 69
Wilcox,
OK...so what exactly was your tach problem and the solution? Someone else with a similar problem, it might be me, could find this thread in a future search and be left wondering. Tach problems seem to be an enigma, but understanding specific problems have specific solutions can demystify the working of the unit. Thanks to you and Willcox for sharing the message thread exchange.
Old May 8, 2011 | 11:48 PM
  #39
puzzigully's Avatar
puzzigully
OK,
the original Tach circuit board was fried and did not work.
I got a local (in the US) shop to replace for me.
They obviously only fitted the board and nothing else!
When power was supplied to the tach, it sat well below the ZERO.
Upon starting, at idle, it still sat below ZERO, by approx 500rpm - a little blip on the gas brought it up.
At highway speed the Tach seems to read high and when accelerating the tach needle seemed to climb faster than the engine note would suggest.
When I zero-ed the tach as per Wilcox's instructions (albeit in the car), when power is suppied, it reads zero and upon starting, at idle, it reads a believable figure.
I need to follow up to confirm it is reading accurately with a dwell meter AND at higher rpm's - then take it out for a drive
Old May 9, 2011 | 09:37 AM
  #40
0Willcox Corvette
Former Vendor
Glad you figured it now...
Willcox
