Tach repair help
If the needle moves freely I'm guessing that the mechanical assembly is OK unless a wire is broken.
Was the tach ever working or has it always been stuck at 2K?
Rick B.
First.. do you have the tach filter in place... if so disconnect it and plug up your tach wire to the distributor.
But.. here is a testing help page for you... following this should help you figure out your issue.
http://willcoxcorvette.com/repairand...lp.php?hID=290
Willcox
This is copied from another thread, I hope this helps you too!
The tachometer in your car works off 12 volts, a ground and what is called a square wave signal generated by the distributor. The 12 volts and the ground are supplied to the tachometer by the printed circuit on the back of the speedometer and tachometer housing. The signal is supplied from the distributor through a filter and then straight to the tach.
Before you pull the tach out of the car lets test some things real quick.
un-plug the tach filter from the system and plug the tach in direct! This will take the filter out of the system.. Start the car and see if the tach works.
Here is where you'll find the filter.
If the gauge works from by-passing the filter then you should replace the filter.
If the gauge fails then pull the tach/speedo housing from the car and go to this step by step page on how to figure out the problem. It will tell you how to remove the tach from the car in a matter of minutes and also take you step by step on how to determine if you have a wire issue or a board problem. This was updated recently with new pictures and details!
If you get to the point where you need to replace the board, we have a video on youtube which will show you step by step on installation as well as how to do the zero set.
18243
Willcox
The tach was inop when I bought the car so it has been stuck at 2K since I picked it up. The first time I did the tach filter bypass check there was no change in needle position but my connection with the jumper was questionable. I now have sufficient wire length and proper connectors to try it again.
When you turn on the key.. the needle should zero out.. if it has no power it will store the last signal received.
check this out.. post again..
Happy Easter..
Willcox
Happy Easter..
Willcox
Rick B.
Rick B.
Sounds stupid but do you have the fiber washers installed on the prongs on the tach. I did not on the 82 I was working on and Ernie clued me in on this. I did not buy the board from Ernie and it did not have the washers but he was very helpful in this for me. The tach now works great after Iinstalled the washers in insulate them. Just a thought.
I have 8.7 volts between the 12V post and ground. I have 8 ohms between the signal post and the tach wire. I did some research and found there is also a signal coming from the 7 pin ignition module inside the distributor that drives the tach. I have not checked this but I do have a new module on hand.
As always I appreciate all of the help I've received not only on this task but my entire ordeal on this resto.
Our boards are made like the original boards.. they don't need washers..
But.. I'm not sure where Talley got the board from he used and so this may be the issue...
Your car is to easy to pull the tach out of.. I think at this point..
Pull the tach out of the car.. and hard wire it!
Just run a jumper from the alternator to the positive post, and a ground from the engine to the ground post. Then run a jumper to the coil terminal on the distributor bypassing the filter and put this on the input signal stud on the tach.
This will tell you if the tach is the problem... it will eliminate either the tach or the car...
The board in most cases is the cure.. but there are cases where the issue is the movement.. I can test the tach for you and there is no charge..
There should be aprox. 12 volts between the power and ground clip..
And we put filters in the board to keep down spike issues from car problems but if there is a dead short it is possible to blow the board.
Do a hard wire and let me know what you find.
Willcox
are you saying that when you turn the ignition key to "on" the tach should read zero before starting?
I think i have a problem with my tach (a US shop replaced the circuit board for me) in that it sits below zero when at idle, but seems to increase faster than the engine does..
looking at your video, it seems as though I need to set my zero and adjust the potentiometer using your signal generator...
sorry for the Hi-jack....
