Carpet from wilcox... does anyone have the same problem i have?
Has anyone installed willcox carpet on a convertible? Do you have the same carpet look as i do?
I have the older carpet on top of the new willcox carpet.
Jim
Rodney
Remember, Willcox isn't a manufacturer. They distribute a producers carpet.
I fully understand your frustration. The carpet material itself is very good but the way it's 'tailored' is VERY different from the original. I guess this doesn't matter to most people. I still think Knock carpet is the best choice from what's available.
I've had 2 different new sets of carpet in my 71 coupe.
The cut and binding of the piece for the rear floor and bulk-head is very different than the original in ALL the mfgs I've looked at.
The wheel-well pieces are sent out with lots of extra material to be cut as it's installed. It's a lot of work but can installed with very good results.
I ended up not using any of the carpet from one manufacturer, and just the 2 front pieces and seat bulkhead piece from another. I re-used the original carpet and jute padding from my coupe for the rest.
I also reused the heel and dimmer pads from my original carpet. (Moved them to the new carpet.)
I found the same differences in the ear bulkhead carpet as your pictures show. It extends too far up the bulkhead and doesn't 'dip' down art the ends.
I spent a tremendous amount of time installing the carpet.... TWICE! Still have 1 1/2 sets sitting unused in my basement.... and don't know what I would have done if I couldn't have reused some of my original carpet.
1&2 Here's a picture of the rear bulkhead carpet.... it looks like yours.
3&4 Here's why I changed the heel/dimmer pads.
5 I had problems with the fit at the front too... carpet was too short. I had to shift it forward so the plugs could be used.
If I can answer any questions I'd be happy to.
Regards,
Alan
Once the carpet was resewn in the bulk head area I set it out in the sun on a nice hot day. It actually laid down very nice and yes it still needed some trimming but turned out excellent. Make sure it is good and hot and that the car is in the sun so that the sun can still beat on the carpet a bit until you are done.
My 70 did not have the dimmer pad originally and the heel pad is as close a repro as you can get.
Bill
I PMd him a link to this thread, so hopefully he gets with you soon...I know he will do his best to get things figured out for you
Anyone know for sure?
Leurja, please send me those pictures to Willcoxcustomerservice@willcoxcorvette.c om. along with the order number if possible and please include your full name so I can dig up the order info. This will allow me to send them down to ACC first thing in the morning and get this resolved for you asap.
I'm sorry for the issue, but we will get this resolved quickly.
Willcox
Willcox
Jim
The carpet on the rear floor and bulkhead....
I believe the 68-69 bulkhead carpet had 2 different 'tab' configurations for coupe and convertible. I'm not sure if either was like the 70-72 carpet.
I believe the 70 coupe and convertible were different from each other, and both were different from the 71-72 coupe and convertible, which were the same.
The 70 coupe and convertible ran further up the bulkhead and had a very small 'tab' at each upper corner. The 71-72 stopped a few inches lower and had a very pronounced 'tab'
Regards,
Alan
Here're 3 pictures of my 71 coupe original carpet. Both sides.
If you look at a 68, 69 or 70 assembly manual, they only show one rear compartment carpet. There's just a note about cutting a hole, when the carpet is to be used in a convertible.
The 71-75 assembly manuals actually make note of 2 different rear compartment carpets, one for coupes and one for convertibles.
I'm guessing that GM probably made a change to the convertible carpets in 70-71, so that it fit better in back and/or didn't interfere with the deck lid hinges.
In luerja's case, I agree with Wilcox that he got the wrong rear carpet.
