Another Ride Height Question (w/ pics)
Old Apr 24, 2011 | 06:08 PM
JGreen's Avatar
JGreen
Default Another Ride Height Question (w/ pics)
Looking for some advice. I have a 75 that has had a frame off restoration completed about 8 years and 2,000 miles ago(started by previous owner, finished by me). I am not sure what springs I have in the car, but lately everyone I see comments on my "4 wheel drive vette". I have a 350 with aluminum heads and an aluminum intake, and I do not have a spare tire...so I understand there is a little less weight in the front and rear than original. Take a look at these pictures and let me know what you think. I know I can lower the rear with longer bolts, but am I going to have to cut the springs in the front? I checked, and they are in the pocket correctly.
Driver Front:
Driver Rear:
Pass Front
Pass Rear
Overall Driver Side
Overall Pass Side
Thanks for any insight you can provide.
Old Apr 24, 2011 | 06:21 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Were the pictures taken w/ a full or empty gas tank, I only ask because I can see a difference in my rear ride height full or empty there is about an 80 lb. difference.
Old Apr 24, 2011 | 06:33 PM
Alan 71's Avatar
Alan 71
Hi JG,
That's a GREAT looking car!!!!
I'll ask about the rear spring.... is it the original or a service replacement? If it's a replacement, have the shipping 'bands' been removed?
Can you post a picture of the rear suspension?
Regards,
Alan
Old Apr 24, 2011 | 07:54 PM
Paul L's Avatar
Paul L
You have not stated the size of your tires.
Old Apr 24, 2011 | 08:00 PM
72LS1Vette's Avatar
72LS1Vette
When you say the front springs are aligned in the pocket, which pocket are you referring to, the upper or lower?
Rick B.
Old Apr 24, 2011 | 08:24 PM
JGreen's Avatar
JGreen
I filled the tank, then drove about 30 miles, so I would estimate 3 gallons shy of full.
Old Apr 24, 2011 | 08:44 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I have a 77... and mine had the same 4x4 look until I did a few things to fix it....I went to an 8 in bolt, and i used a vbp 550 with a coil cut out..itnow sits almost 3 in lower in front and a good 2+ in the rear,,,,these cars always sat high in the seat..
3+ years ago
last week
jeff79''s Avatar
jeff79'
St. Jude Donor '10
My '79 is 27 3/4" in the front, and 28" in the rear with the grand touring package from VB&P. That's with a full tank. I can adjust the rear if I want, but it's right where I want it now.
Old Apr 24, 2011 | 08:48 PM
JGreen's Avatar
JGreen
Originally Posted by Alan 71
Hi JG,
Regards,
Alan
Alan
Thanks for the compliment. The painter did a fantastic job. I tried to take a couple of pics of the rear suspension, but they did not turn out very well. I found one before the body was on, if that would help.
I will try to get some from underneath the car in the next day or so. I tried from the floor but they turned out pretty bad.
Old Apr 24, 2011 | 08:51 PM
mar's Avatar
mar
Didn't the later (Mid-70's) cars use a thicker body mount shim set to get the bumper height up??? seems like I read that in some of my source material?
Old Apr 24, 2011 | 08:54 PM
JGreen's Avatar
JGreen
They are 225/70/15
The bottom...I guess I didn't realize there was a top pocket too. Is it safe to assume that if they are aligned in the bottom, they must be aligned in the top too?
Old Apr 24, 2011 | 08:59 PM
JGreen's Avatar
JGreen
I hadn't heard that. I'll have to research that...
Ptroxx
How much drop did you get total? It looks like yours was an inch or so lower than mine now...and it also looks like its about an inch or so lower than I am looking for now. Your setup might be just what I need.
Old Apr 24, 2011 | 09:03 PM
volition's Avatar
volition
I had the EXACT same probem. I had what were supposed to be correct springs and had huge wheel gaps. I swapped out VBP springs and the height looks perfect now. Give me a minute I'll find some before and after pictures. This was a direct swap and I did not cut any coils, I think you'll like it.
Old Apr 24, 2011 | 09:13 PM
volition's Avatar
volition
As promised
Before:
After:
(The tape measure isn't crooked, the angle I was holding the Camera is)
Old Apr 24, 2011 | 09:39 PM
ptroxx's Avatar
ptroxx
I have 255-60-15's... and i just went and checked again.. front is about 26 1/4 and the rear is about 28 1/4 -1/2... It seems my rear end has reaised since my last measurement,,, I was 27 1/8- 26 7/8 ..
I had 3
235's before...
I think I went about 2.5in ini the front, nd about 2 in the rear....I dont have my org #ers from when I started, It got tossed in the trash...
I need a little more in the rear.. I may go to a little longer bolt, Like a 9in.. or cut the 10 in down,,,
Ptroxx
Old Apr 25, 2011 | 12:38 AM
Grumpy 427's Avatar
Grumpy 427
My 1980 with 255/60R/15. And Fibreglass easy ride spring. Sits 27 " in the rear and 28" in the front.
Old Apr 25, 2011 | 01:55 AM
sokoloka's Avatar
sokoloka
I could be terribly off (ditched my leafs for a composite spring), but based on these two photos it looks as if the shipping "bands" are still on your leaf pack. This could be part of the reason your rear end is riding as high as it is.
To Another Ride Height Question (w/ pics)
