Stalling when cruising up hills...
Old Apr 26, 2011 | 01:46 PM
Birdman's Avatar
Birdman
Default Stalling when cruising up hills...
Took the car out for a spin yesterday and today. Had NO problems whatsoever. Sang through the RPMs without trouble, idled fine, and made me actually relax for once..
But today when I returned from seeing some family who live out there where there are quite a few hills, it started having problems. When I'm simply cruising up a long and not necessarily steep hill, the car starts to buck and stall and want to die. I remedy this, I have to get it out of gear, and feather the throttle until it revs smoothly, then put it back into gear...but if I'm still travelling up the hill, it will continue to do it until I get to the top.
It has no problems going up short hills, or accelerating fast up short hills...but give it a gradual incline over the distance of a quarter mile, and it wants to cough, sputter, and die.
I've played with the carb, but nothing seems to work..
1968 Convertible
327 (Mechanical fuel pump, Barry Grant Road Demon 650cfm, HEI Summit, stock gas tank, and 7-8 psi at idle.
4 speed manual
Old Apr 26, 2011 | 01:51 PM
birdsmith's Avatar
birdsmith
Float level?
Old Apr 26, 2011 | 02:11 PM
Birdman's Avatar
Birdman
Originally Posted by birdsmith
Float level?
:EDIT:
There are 3 lines on the sight glass. The middle one is where the gas is supposed to sit at, but right now they are on the lower line..how do you adjust those?
Old Apr 26, 2011 | 02:22 PM
Donnie Meyer's Avatar
Donnie Meyer
Might be fuel starvation. Check the fuel pressure/replace the fuel filter.
Dirty gas tank?
could also be a coil going bad.
Donnie
Old Apr 26, 2011 | 02:31 PM
Birdman's Avatar
Birdman
Dirty gas tank?
Donnie
It feels like fuel starvation.
Fuel pressure is a constant 7-8 psi.
No fuel filter that I am aware of.
Brand new Summit HEI distributor..no external coil.
Old Apr 26, 2011 | 02:52 PM
Birdman's Avatar
Birdman
Could it be the fuel pickup line?
Old Apr 26, 2011 | 03:59 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
How much gas is in the tank?
Old Apr 26, 2011 | 05:45 PM
Birdman's Avatar
Birdman
Full tank. But could it still be the fuel pickup line? You'd think that if it were the carb, I could replicate the problem without having to find a back country road, with hills... It's a gravity thing. So either the fuel pickup line, or the fuel level in the bowls of the carb..
Old Apr 26, 2011 | 11:17 PM
Donnie Meyer
GM put a sock on the end of the gas pic-up tube. When the gas tank gets a lot of crap in it the sock gets partially blocked & restricks the fuel
You might want to pull the sending unit & see.
Donnie
Old Apr 26, 2011 | 11:50 PM
Birdman's Avatar
Birdman
Donnie
I've seen that sock before... I've also noticed that my fuel gauge likes to bounce around a lot...
How do I pull the sending unit? Do I have to drop the gas tank to do it?
Old Apr 27, 2011 | 04:04 PM
LB66383's Avatar
LB66383
No. Drop the spare tire carrier and you'll be able to get at it. Obviously, since it's in the bottom of the tank, you'll have to drain the tank before removing the sender.
Old Apr 27, 2011 | 04:15 PM
Birdman's Avatar
Birdman
Awesome, thanks.
How do I make sure it is the sender before I do that? Or before I buy a new/different one..
To Stalling when cruising up hills...
