Heater Core rebuild - missing part. Help needed!!
Old Apr 26, 2011 | 08:06 PM
jdolomount's Avatar
jdolomount
Default Heater Core rebuild - missing part. Help needed!!
I'm still in the process of doing a body off chassis restoration. While the body is clear of the frame and engine I figured it was a good time to clean up and detail the engine compartment. One thing I had noticed when taking the engine out of the car, years ago, was that the heater core was loose inside the firewall, so it was on my list of things to investigate.
This weekend I removed the outer heater box. This revealed that someone had been in there before and it looks like the core may have been changed by going thru from the engine side. Bubba must have had trouble has the inner frame was distorted, the retaining clip on the right was bent over and the clip on the left side is missing. He also didn't have the foam seal around the core tubes.
I'd like to put the heater core back in properly. I'm pretty sure I can restore the clip on the right side to it's proper shape but, of course, I no longer have the clip for the left side. Does anyone out there know where I can purchase this clip?
As I cannot take a photo of the missing part, I borrowed images of it from photos on a previous thread..... Hopefully the owner of those pix will not mind my hijacking portions of his photos. Hopefully this link will work......
http://i469.photobucket.com/albums/r...reRetainer.jpg
Your help here guys is greatly appreciated! Thanks in advance.
Old Apr 27, 2011 | 12:32 AM
gbvette62's Avatar
gbvette62
Do you have air conditioning? I have a dozen AC heater boxes, most will cores still in them, but no non-air boxes with cores. I can't remember right now if those clips are used on both heater cores, the AC only, or the non-air only.
I'm leaving for Spring Carlisle Wednesday morning, and won't be back till Sunday night. If I have the time before I leave, I'll look to see if any of my old cores, have the clips on them. I post Wednesday night, if I'm able to find any.
Old Apr 27, 2011 | 05:08 AM
jdolomount's Avatar
jdolomount
Default Missing Part
My car does not have AC..
I'm the other way around... I have never seen a AC heater box so I don't know if the clips are there for sure or not. However, the picture I found on the forum was said to be from a AC car so they just might be there.
That would be great if you can help out. Thanks!!
Old Apr 27, 2011 | 11:47 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I should have one of these used.. let me check tomorrow and I'll post up..
Willcox
Old May 1, 2011 | 02:35 PM
jdolomount's Avatar
jdolomount
If either of you guys can help out, I'd greatly appreciate it.
Old May 3, 2011 | 08:34 PM
0Willcox Corvette
Former Vendor
Ugg.. I forgot.. I'll look for you tomorrow.. sorry..
Or.. better yet.. I'm sure I have it, give Norm a call tomorrow at 800-588-3883.
Old Jun 13, 2011 | 03:23 PM
jdolomount's Avatar
jdolomount
I have had no luck to date getting this part. Thanks though to Willcox and gbvette62 for trying. I appreciate the effort guys!!
Anyone else out there with any suggestions here i can get this clip??
Old Jun 13, 2011 | 03:40 PM
mysixtynine's Avatar
mysixtynine
Took a websearch and found this
http://shop.docrebuild.com/1968-1979...eretainer.aspx
Old Jun 14, 2011 | 03:32 PM
jdolomount's Avatar
jdolomount
Originally Posted by mysixtynine
Thanks a bunch my69.
I had a look thru their catalog but never thought to check the site online. That's great!
Old Jun 15, 2011 | 12:51 AM
Legacy Stables's Avatar
Legacy Stables
got to love the good doctor.
To Heater Core rebuild - missing part. Help needed!!
