Mystery fan
Old Apr 27, 2011 | 10:36 PM
DonsShark's Avatar
DonsShark
Default Mystery fan
Mounted between the clutch-driven engine fan and the radiator of my '79, is a second fan. It is shallow, the vanes within a ring about 1-1/2" deep, apparenty free turning- not powered, the vanes spin freely- and mounted from its center to the stock shroud by metal spokes- evidently stock, not an aftermarket item.
I cannot find anything about it in manuals, neither my buddy's '70 nor his brother's '76 has anything like it.
Anyone know what the story is about this?
Old Apr 27, 2011 | 11:49 PM
BHRIG's Avatar
BHRIG
PICTURE, PLEASE>>>>>>
Sounds aftermarket.
Old Apr 28, 2011 | 01:26 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
79 and 80 L82/Air Conditioned Vettes got the auxzillary electric fan.
There's also a flap or trap door in the bottom of the fan shroud.
The 79 also got the rubber extensions on the lower air dam(spoiler).
There's a thermo switch mounted in the pass side head between the rear 2 sparkplugs. Turns on at I think 238 degrees. I have never seen mine run.
Fuse is located in the very lower left corner of the fuse panel.
I think all 81/82s got the fan, but not the trap door.
Old Apr 28, 2011 | 02:19 AM
DonsShark's Avatar
DonsShark
Thanks, great info. Mine is an L82 with a/c, but shortly before it went into storage several years ago I had a rebuilt 4-bolt main dropped in, long story but I'm finding a bunch of shortcuts the mechanic took, the thermo switch I'm sure never got connected. Mystery solved, I know where to start. Thanks again.
Old Apr 28, 2011 | 07:17 AM
Paul L's Avatar
Paul L
Ref.: 1979 GM Corvette Factory Shop Manual.
Old Apr 28, 2011 | 10:57 AM
7T1vette's Avatar
7T1vette
I suspect that fan is there to operate after you shut down the engine. After shutdown, the engine block residual heat can raise coolant temps considerably. This 'auxiliary' fan could run after shutdown to keep the coolant from boiling or puking out coolant on the ground. It was likely the "precursor" to fully electric fans which can operate the same way.
Old Apr 28, 2011 | 11:21 AM
Mike Ward's Avatar
Mike Ward
'73 and up Corvettes have a coolant recovery tank that catches and returns coolant overflow from heat soak back. No need for a fan for that reason.
Old Apr 28, 2011 | 11:32 AM
Paul L's Avatar
Paul L
For some reason I have always thought it was part of the RPO ZN1 Trailer Package (1,001 units in 1979). But...I really do not know.
7T1,
Note from the pic that the fan is powered when ignition is in the RUN position.
Old Apr 28, 2011 | 11:54 AM
qwank's Avatar
qwank
i have the fan on my'81. does it pull enough CFM to work by itself without the belt driven fan, if a lower temp thermo switch was installed? what about a lower temp thermo switch and a larger aftermarket fan? it would be nice to make use of the factory wiring to get rid of the belt driven fan
Old Apr 28, 2011 | 11:58 AM
7T1vette's Avatar
7T1vette
Interesting. It must be there just for low speed/idle cooling for the A/C. Live and learn!
Old Apr 28, 2011 | 12:28 PM
Paul L's Avatar
Paul L
I really do not know the purpose of that fan. Note that it switches on at 238*F. Many drivers are horrified if the temp gauge touches 200*F.
Old Apr 28, 2011 | 03:27 PM
DonsShark's Avatar
DonsShark
Has to be a worst-case backup, what with its presence on on the "hi-po" L82 with a/c. Paul 74, thanx for the manual page print-out, I was able to locate it in my manual, missed it first time around.
Old Apr 28, 2011 | 04:11 PM
7t9l82's Avatar
7t9l82
i would also like to explore a lower temp switch and bigger fan if anyone has any thoughts
Old Apr 28, 2011 | 06:51 PM
hugie82's Avatar
hugie82
I unplugged the wires from the temp switch and installed a toggle switch under the dash. Worked great on hot days in traffic with the a/c on Waiting for the engine to hit 238* is a little too late IMO
Old Apr 28, 2011 | 08:16 PM
doctorgene's Avatar
doctorgene
Yes Sir; The Auxiliary cooling fan is used for the purpose of cooling down the engine when in slow traffic & overheating might happen. It is powered through the Circuit breaker in the fuse panel when the ignition switch is in the run position. The fan motor is controlled by an engine temperature switch which screws into the engine block. When the engine temp. reaches approximately 238 degree F, the switch closes, completing the fan motor circuit to ground. The motor frame is its ground terminal and is insulated from engine ground by the plastic shroud surrounding it. When engine temp. decreases to approx. 201 F. the switch opens the fan circuit, shutting the fan off. Gene
To Mystery fan
