windshield change
Old Apr 29, 2011 | 09:18 PM
7t9l82's Avatar
7t9l82
Default windshield change
i need to change my windshield (cracked) I'm going to have i removed and replaced a couple days later because i want to clean up the frame and treat it to kill any place for rust to start. also going to try that Eastwood rust spray for inside frame rails thought I'd try to spray that inside the windshield. frame i want to try and make sure rust does not become an issue
Old Apr 29, 2011 | 09:48 PM
myk7's Avatar
myk7
I hope there aren't any surprises, good luck
Old Apr 29, 2011 | 09:52 PM
7t9l82's Avatar
7t9l82
less than 12k actual miles always garages don't forsee a big issue just don't want one down the road
Old Apr 30, 2011 | 08:06 AM
Alan 71's Avatar
Alan 71
Hi 7T9,
Perhaps you should have the the installer test fit the new windshield so the ss trim can be test fit too.
There are often posts about gaps between the glass and ss trim because the new windshield was installed too close to the frame.
It's some extra work but to my eye worth it.
Regards,
Alan
Old Apr 30, 2011 | 08:24 AM
MrJlr's Avatar
MrJlr
Originally Posted by Alan 71
Hi 7T9,
Regards,
Alan
Old May 1, 2011 | 03:25 PM
Roco71's Avatar
Roco71
What Alan is saying is totally correct. I followed his recommendation and ended up dry fitting mine three times to get the height correct. Was not all that hard well worth the effort.
Old May 1, 2011 | 08:27 PM
Timsride's Avatar
Timsride
Hi 7T9,
Regards,
Alan
Also I was told when I did mine to use metal etching primer on bare steel where the seal is going to be used, and give it a week to cure.
Old May 1, 2011 | 08:31 PM
7t9l82's Avatar
7t9l82
I'm leaning to using por-15 very tough stuff
To windshield change
