Th 350 autobox - workings?
Old Apr 30, 2011 | 03:42 PM
corvettedave383's Avatar
corvettedave383
Default Th 350 autobox - workings?
Can you put the th 350 into 1st, when your speed is above that gear or does it prevent from doing that??
cheers
dave
Old Apr 30, 2011 | 03:49 PM
DRIVESHAFT's Avatar
DRIVESHAFT
On a stock TH350, if your going too fast it will not go into 1st even if you manually select 1st gear
There are numerous shift kits that will allow you to shift into 1st at any speed.
Old Apr 30, 2011 | 04:06 PM
corvettedave383
my th350 does have a shift kit, not sure which one
I did mistaken put it into 1st today, like you say it didnt engage 1st tho, but the gearbox feels like smoother between gear changes now, but before changes used to be more sharper, you could feel the change, because of the shift kit, have I damaged anything??
cheers
dave
Old Apr 30, 2011 | 04:22 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
If the shift kit was done properly, when you placed it in first, It should have gone into first no matter what speed! The rear end would of likely locked up due to the drastic change. Since yours did not do that, I don't believe you have a shift kit. IF you do then it was not installed correctly or it was not done for that kind of shifting.
To Th 350 autobox - workings?
By Michael S. Palmer | 2026-06-03 11:00:24
