OK, I need some help. I never thought it would be so difficult. Maybe I am just looking in the wrong places. I have a broken piston and want to change all 8 out. I have a 1970 454 LS5 motor with stock pistons. Where can i go to get the stock pistons?
I looked for stock pistons for my '70 454 a while ago. Can't get them 'off the shelf' due to the (unique for that year)10.25:1 compression, or so several speed shops told me. They could take an existing piston and custom modify it (expensive!) or go with a different piston and lower the compression. And that's what I did, went with about a 9.5:1 ratio (Keith Black pistons) for pump gas and got the valve seats fitted with hardened inserts. Now, this is what I was told and given the smattering of research and cross-shopping of stores (and advice from some old-timers) I tend to believe it.
Good luck!
BTW: Here's what I found in my oil pan that suggested I had a 'broke' piston:
Reason: ppl love photos.
I've never tried but I thought piston manufacturers like Ross could duplicate pretty much anything at a decent price.
Curious as to why a piston skirt would break.
Othet than this here: http://cgi.ebay.com/ebaymotors/Genui...op=12cessories
You are going to put an unworn piston and new round rings back into a hole that is nolonger round. You will have sealing issues from the start. How many miles on the engine?
I agree with the "{time for rebuild" suggestion if it is in your budgit. If not look for a used piston on Ebay.and don't be surprised if there is a compression or blow by issue.
Suck it up and do the right thing, ... rebuild the motor !
it is the only way to ensure those little broken metal peices,
do not cause a problem in your future.
For the big block guys. I have found out on big blocks especially 454's that the back of the timing gear (the one that bolts to the cam) will wear into the block due to lack of oiling. the trick is too drill a .050 hole at 12 o clock in the front of block above the #1 cam journal. The hole you drill will tap into a oil gallery. This will fix the oiling problem and SAVE your block! I have pics some where I will have to dig them out and post them up.
SO pay attention the this area when you tear your motor down.
Jeremy
Yes, I Know, That's why I said you USED to have to mill the face. As a matter of fact if the block face is damaged you may still may have to mill it smooth. That torrington bearing deal began a long time ago, using one that was from another application thus reguired relief in the block face.
I still find core blocks that have so much wear damage they require some attention.
Good luck!
I did exactly the same thing in the mid 80's when I had to tear down my LS5.
The machine shop recommended the 9.5:1 compression ratio to ease finding gas with sufficient octane. I had hardened valve seats put in for the exhaust valves. Wonder at time how much HP the .75 drop in compression ratio cost...
If I were to do it over I'd probably look at restoring to 10.25:1 and installing a modern cam design to compensate.
Originally Posted by Ben Lurkin
Several manufacturers make timing sets with a captured torrington bearing on the cam gear. No need to mill anything.
Very interesting to hear. The face on my block was worn. I'm not sure what the last shop did to address this. I usually tear the engine down but with the cost of big block parts had paid the shops to reassemble.
