Spreader bar install
just wore out the poly upper bushings some months ago, put in rubber, still fine....
Dang, to all the shims you have on the control arms. Is that due to the new spreader bar or were they there prior to the install? I got maybe 3 shims per entire side and I still have a bit of negative camber. Is your front suspension stock?
I have no explantion.
Determined the bar position, took it to my brother's shop to weld the tabs, repainted and installed in the afternoon.
This is the kit jb78L-82 offered up in another thread. It was just as advertised and it was a pleasure to deal with you. Thanks Jeff!
Brad,
How does The Vbp bar effect the car's handling, ride , or steering . That bar is much beefier than my speed direct bar but my bar has really helped just the vbp bar was too tight for my sb with a mechnical fan!
Big improvement. It was especially noticeable on the tracks in the Interstate and state hwy. Same again when changing lanes cresting the crown. Tracks straight and true. In the twisties, the front held its line much better and deflection when hitting patches & dips was more sure footed.
My next step is to replace the original, never touched, steering box with a Borgenson and eliminate the hydraulic ram and control valve. Have never been a big fan of that design on vehicles intended for spirited driving.
PS: I have already redone the majority of the suspension with a 330lb rear composite spring, Bilsteins on 4 corners, heim joint rods in the rear, new TA bushings, lowered the front by taking 1 coil off the stock springs and upgraded to 17" wheels & Nitto tires.
I had the same experience with the speed direct bar-BIG Improvement-thanx for the feedback. Shark Bar is going in behind the rear seats this weekend for even more frame stabilization. I have a similar setup but a little more aggressive and do have a recently custom rebuilt/blue printed OEM steering box which now has zero play. I am shocked how good the OEM box is when properly rebuilt, hand adjusted, and with a few custom internal components to eliminate the inherent sloppiness of the recirculating ball steering.
My setup in front:
OEM 1 1/8 inch front bar with poly endlink and mounting bushings
upper and lower poly control arm bushings
Bilstein Heavy Duty shocks with poly bushings
Blueprinted/Custom rebuilt OEM Steering box
550 springs 1 inch shorter than stock
Speed Direct Spreader bar
255/45/17 ZR Kuhmo Tires on SLP rims
In the Rear:
360 Composite Spring with poly cushions
Competition Heavy Duty adjustable Struts with Heim joints
Bilstein Sport Shocks (30% stiffer than the front HD's)
3/4 OEM type rear sway bar with poly mounting bushings
255/50/17 ZR Kuhmos tires on SLP rims
Hope that helps!
My setup in front:
In the Rear:
Hope that helps!
My setup in front:
KYB shocks
Sloppy original OEM Steering box
Gymkana front springs
In the Rear:
Gymkana 7-leaf steel spring
VB&P smart struts - 1/2" aluminum spacer between bracket and diff
KYB shocks
Offset trailing arms w/ poly bushings
VB&P Crossmember reinforcing kit
Original rear sway bar with poly mounting bushings
My setup in front:
KYB shocks
In the Rear:
KYB shocks
I would seriously consider replacing the KYB's (as you noted) with Bilstein's (either HD's or sports or both like I have). Most importantly, you have to do something with the OEM steering box. You probably can guess that I am NOT a fan of replacing OEM designed suspension steering components with aftermarket ones that were NOT originally on the car like the Borgeson/Rack and Pinion steering so I opted to maximize the saginaw recirculating steering box and I am VERY happy and surprised at what it can do if setup correctly. The feel is excellent now with zero sloppiness and play. To me the major advantage of the Borgeson/R&P steering is that they have quicker steering ratios than the 16:1 of the OEM box but I don't need quicker steering on the street. Obviously I am quite familair with the R&P steering on my other cars and I believe that my 2008 300 has a Borgeson type box which I do like very much.
Lastly,
I would ditch the steel spring for a 360 composite. The spring and shocks will transform the ride and handling alone!
I will give an update on my car once the Shark bar is installed behind the seats!
What it seems is that I'm feeling additional rear roll and sway and some added over steer now. Am wondering if the spreader bar is increasing the effect of the stock 7/8" front sway bar. Being a small block car, it doesn't have a rear sway bar.
Thoughts?
From what you've described, it's quite possible you might have gained more grip from the latter effect than lost due to the former. In addition, you may also be feeling a more pronounced difference in roll desires. And, there's such an animal known as roll-oversteer where excessive roll in and of itself causes the rear suspension to move into very adverse dynamic alignment, but this usually occurs only when there is far too soft a rear spring/bar/shock combination. With a 330# rear spring you really shouldn't be in that territory.
As for bar adjustments, better to listen to what your backside tells you the car needs in order to put balance where you like it rather than to go by speculation alone. Generally, you only stiffen up the rear if you have understeer and don't wish to soften up the front, but be careful to find out what the car does at its limits in a safe place.
There's also a chance your rear ride height and/or roll center might need adjustment.
Your last sentence was also something I was thinking about as I do have the car lowered with 8" bolts and 1 coil removed. The F/R balance could be out of whack with too much to the front. Would a too low rear result in the roll-oversteer condition?
I'll take it to my brother's shop and put on the 4 wheel scales.
What is the optimal F/R distribution ratios?
It definitely has a different feel when entering and hitting the apex of hard corners. My normal pre-cornering "set up" didn't result in the normal response.
Thanks again.
