Spreader bar install
Old May 13, 2011 | 11:28 AM
  #41
71rdster's Avatar
71rdster
I had a spreader bar on my wish list, and after reading your post ordered the Shark Bite Spreader from Speed Direct. Brown dropped the package off last night. The package was so light, I wondered if they had actually packed my parts. All the pieces look very well engineered. I can't wait to install it.
Old May 13, 2011 | 12:01 PM
  #42
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Get that glass Fuel filter off there now!!!!
You wouldn't believe the number of car fires that are caused by them.
Old May 13, 2011 | 05:17 PM
  #43
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I would also replace the rubber lines... Im getting ready to do that to mine asap...
Old May 13, 2011 | 07:08 PM
  #44
doctorgene's Avatar
doctorgene
Yes Sir; Had to remove my Air cond. Compressor because the bolt was turning. Couldn't get a wrench in behind to hold it. Also had to remove a brace from the air setup, which had a belt protector. Took a little longer than the hour. LOL Have a great weekend Gene
Old May 13, 2011 | 07:17 PM
  #45
Paul L's Avatar
Paul L
Originally Posted by jjanow
I just installed the spreader bar from Speedirect and all I can say is "WOW"! what a difference it feels like a different car. The front is much stiffer when going over bumps.
What cut-off valve do you have on that heater hose.
Old May 13, 2011 | 08:57 PM
  #46
fauxrs's Avatar
fauxrs
Ha, the box they shipped mine in could have held 5 spreader bar kits at least...packaging clearly not an issue with speed direct. thats like 2 or 3 spreader bar kits ordered since I posted this, I should be getting a cut from speed direct
Old May 13, 2011 | 09:27 PM
  #47
jjanow's Avatar
jjanow
I have the aluminum filter and new new hard lines and have moved it up to the top of my to do list. Thanks for the input.
The heater hose ball valve is from the local home improvement store in the plumbing section.
Old Jul 8, 2011 | 12:01 PM
  #48
silver79's Avatar
silver79
hi that heater by pass did it make a difference in the interior cabin heat? what size is it?
Old Jul 8, 2011 | 03:14 PM
  #49
worship79's Avatar
worship79
Seat of the pants impression is a noticable improvement in turn in and steering response, also the front end seems a bit stiffer over bumps
Agreed! Have it on for about half a year now, very satisfied. Except for wanting to upgrade the rear as well now...
Old Jul 8, 2011 | 06:22 PM
  #50
doctorgene's Avatar
doctorgene
Yes Sir; The valve in the heater lines make a lot of difference. The small line takes a 3/4 " Pex water pipe valve, the big line takes a 1 " Pex water pipe valve. You can close them both off, or just one. Have a great weekend. Gene
