pulled motor--NO!!!!!!!!!!!
Old Apr 19, 2002 | 11:17 PM
erika1977's Avatar
erika1977
Default pulled motor--NO!!!!!!!!!!!
well, pulled motor last night-i had decided on rebuilding it--but........MY BLOCK IS CRACKED!!!!!!!!!!!looks like a crate for me--i was originaly thinking the "enigine factory" 383 for $5300, but afew of you told me over priced. how about a ZZ4?
i also got a good look at my front suspension--not bad at all--i do have to chnge my steering parts, but generally pleased about everything else.-oh well, just blowin off steam! :crazy:
Old Apr 19, 2002 | 11:22 PM
72rdstr's Avatar
72rdstr
Default Re: pulled motor--NO!!!!!!!!!!! (erika1977)
Wow, that sux... If you're serious about a crate motor, you can't really go wrong with the GM series.
Here's a couple of good links to do some shopping... http://www.sdpc2000.com/ http://www.sallee-chevrolet.com/
I really like the 502s but don't want to change rad, shroud, etc... so I keep looking at the ZZ4 or 385 with the "hot" cam.
Sweet and hard to beat!
:cool: :D
Good luck
Old Apr 19, 2002 | 11:25 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: pulled motor--NO!!!!!!!!!!! (72rdstr)
after seeing 74vette's zz4 run the other night im a strong believer for gm crate motors like the zz4 and the 383.
Old Apr 20, 2002 | 12:04 AM
C3 Shark Tank's Avatar
C3 Shark Tank
Sorry to hear the block is cracked, but now you can get into the engine compartment and give it a good cleaning before you drop a new motor in. I really like those ZZ430/450 motors, wish I had the money for another Vette to drop one into. You can find nice crate motors for well under 5K.
Old Apr 20, 2002 | 12:18 AM
jackson's Avatar
jackson
If I were seriously considering a small block crate, I'd probably go with GM's HT 383 ... reasonably priced, forged crank, 4-bolt main caps, great warranty, strong right outa the box on 87 octane, awesome potential.
JACKSON
Old Apr 20, 2002 | 12:24 AM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: pulled motor--NO!!!!!!!!!!! (jackson)
Yep, ZZ4 sounds like the way to go. I would.
Old Apr 20, 2002 | 12:33 AM
Steve Straus's Avatar
Steve Straus
jesus christ, $5300 for a 383? My 468 didn't cost that and it's putting out over 600 hp.
Quite a few people have been happy with the ZZ4. If your block is cracked, the ZZ4 is a hot little engine for the money.
Old Apr 20, 2002 | 01:01 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
ZZ-4 great value for the dollar, but before you put it in, go ahead and buy GM's Hotcam. It will really pump it up!
Old Apr 20, 2002 | 01:12 AM
kgraumann's Avatar
kgraumann
After looking into the GM Crate Motors, I decided on the ZZ4. I did not get the hot cam, but it has unbelievable torque, and real peppy. I had to change the water pump. It comes with the long neck version, and I swapped it for the short neck, so my belts would line up. I also had to buy the flywheel, as my old one was not compatible. It was a straight forward installation, and have not regretted it for one second. If your bolting it up to an automatic transmission, it comes with the flex plate. You will also have to get the oil filter adapter.
All in all, the total extra I had to buy was around $200.00.
IMHO, you can't go wrong with the ZZ4. :yesnod:
To pulled motor--NO!!!!!!!!!!!
