427 How much HP?
Old May 7, 2011 | 08:33 PM
richiev88's Avatar
richiev88
Default 427 How much HP?
Hi,
I have just bought a 427 for my vette
Previous owner said it was making 450hp, does this seem right ??
3963512 block, 30 over with TRW's 50cc domes
Isky Z33 solid (250 dur@ .050, .540 lift)
Gm oval port 3931063 100cc closed chambers
weiand single plane, 850 D/P
Cheers
Old May 7, 2011 | 09:00 PM
7t9l82's Avatar
7t9l82
pretty close i would Think
Old May 8, 2011 | 11:28 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
If those specs are correct then the engine has at least 14:1 compression ratio. I don't recall a 50cc 427 TRW piston for use with closed chambered heads, but I don't completely trust my memory anymore these days. Way too much compression for a street engine if that's what your intended use is.
With the specs you listed though; I agree it would be in the 450 hp ball park.
Old May 8, 2011 | 01:19 PM
Grumpy 427's Avatar
Grumpy 427
Just looked up the Trw piston, and the one i found listed that has a 50cc .585 dome is for an open chamber head with 116cc chamber thats 11.66-1 compression. So a closed chamber head isnt going to work with that piston.
Old May 8, 2011 | 02:57 PM
richiev88's Avatar
richiev88
Yes I agree it seems unlikely that compression is that high, Its always been run on race gas.
I have not opened it up to verify, rather second hand info.
Also been told its run 10's in a light car.....
What then would would you guess whe domes are likely to be ?
Trying to figure some new heads to put it in the early 11's compression wise
Old May 8, 2011 | 03:09 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Seat of the pants feel? 450hp should scare the crap out of someone that is not use to driving a C3. How about taking us for a ride in the car via Youtube? Maybe the wifey can do the video'ing, we always like to hear them scream.
BTW - A 327 can run 10's in a light car.
Old May 8, 2011 | 03:48 PM
Grumpy 427's Avatar
Grumpy 427
An 049 or 781 oval port open chamber head with about 12 cc chamber would be good.
Old May 9, 2011 | 05:16 AM
richiev88's Avatar
richiev88
Originally Posted by Grumpy 427
An 049 or 780 oval port open chamber head with about 12 cc chamber would be good.
I have a option to buy some 3946074 casting,think they are 110 chambers ? guy wants good $$ for them, for the same $ could get some new GM heads... hear there are issues with these old alloy heads.. like to keep the compression up, race gas is not much more expensive that pump gas over here, smiles per gallon and the sweet perfume
Old May 9, 2011 | 11:20 AM
cv67's Avatar
cv67
St. Jude Donor '05
Old GM alloys? shoot just get some good aftermarkets and really step up your power game. let the untouchable stuff sit and collect dust somewhere.
tpi421Vette in the C4 tech section can do you a screaming deal on a set of AFRs. Sell your oval ports to offset cost, lighten the front end up build more power and worry less about running compression.
Old May 9, 2011 | 08:27 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
I guess he is going to ignore my request and question.
Old May 10, 2011 | 02:18 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
That's anyone's guess as to what the pistons are w/o pulling the heads. Could easily be 11:1 pistons or 12:5:1 L88 style pistons. Are you sure of the casting # on the heads?
A friend had a similar engine in a 68 camaro in the late 80's and it did run tens. I would be tempted to run it as is and see how it does.
Old May 10, 2011 | 05:36 AM
richiev88's Avatar
richiev88
Nope, all good idea's, wife in vette, unlikely to happen, roads here some what average due to 2 major earth quakes in recent times, engine still on engine stand, will take some video once is installed, 450hp is nice but after having had more hard to go back, 500hp this old girl would be nice......perhaps some AFR's are the plan
Old May 10, 2011 | 09:25 AM
Grumpy 427's Avatar
Grumpy 427
Just thought i would give you this bit of info. i built a 427 several years ago, and spun it on the dyno. The build goes like this.
427 + .060= 440
11.25-1 compression
Eddy rpm performer heads
oval port 122 cc chamber
.585 lift .245/.255 @.050 on 112LSA
Hydraulic roller
Holley Strip dominator intake
850 Dbl pumper carb.
34 degrees total timing.
550 hp and 513 tq.
Premium pump gas motor had good manors and drove nice on the street.
Old May 10, 2011 | 10:00 AM
Ironcross's Avatar
Ironcross
Hi,
Cheers
With out a doubt, 450 is a mild engine compared to some monsters driven on the street....how about a big inch BB with twin turbos in a White Ford Ranger pickup....1400 hp and he`s looking for more....The truck competes in Dyno horsepower contests and he drives it all over to local cruises. The first time I saw the truck with all that junk sticking out of the engine bay I thought 'Ford! But the distributor was in the back of the engine...
.A BIG Chevy and hes looking for more HP.....The only thing I exclude from the street are my race cars that don't have radiators. So 'almost anything goes including single digit 1/4 mile pieces street driven.....all it takes is money and brass *****........
Old May 10, 2011 | 02:37 PM
richiev88's Avatar
richiev88
427 + .060= 440
11.25-1 compression
Hydraulic roller
550 hp and 513 tq.
Nice numbers, would be very happy with that build, thanks for the input
Old May 10, 2011 | 07:16 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
O, I thought it was still in the car. Pull those heads and take a look.
Old May 11, 2011 | 05:47 AM
richiev88's Avatar
richiev88
Yep, have a bad habit of pulling things apart, can't bring myself to put iron heads in the car...
Old May 11, 2011 | 11:14 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Sounds like you need to start tearing into it, since your mind is somewhat made up on going with new heads.
Old May 12, 2011 | 04:18 AM
richiev88's Avatar
richiev88
Yes, think so, have a used set of AFR's coming off a jet boat engine, so will see if they fit budget, engine builder to come forward with specs, soon I hope
To 427 How much HP?
