throttle cable bracket for performer airgap
Old May 11, 2011 | 04:20 PM
boltnut's Avatar
boltnut
Default throttle cable bracket for performer airgap
what bracket are you guys using with your edelbrock airgap intake and stock accel cable ?
Old May 11, 2011 | 05:02 PM
MelWff's Avatar
MelWff
assuming you are using a holley the standard bracket Chevy used with holley's
Old May 11, 2011 | 05:08 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Where can these be bought from? thank you for your reply.
Old May 11, 2011 | 08:30 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
I wanted to use a CSR bracket on my setup. Had to modify the stock accelerator cable by trimming off the plastic cable protector from the wire end so that wire end would fit through the hole in the CSR bracket.
The factory sleeve clamped on the cable end was too far forward then for the CSR bracket so I made my own clamp.
I cut off a 3/4" length of 3/8" dia aluminum tubing and split it into halves. I then used these clam shells to support the cable inside the cable mount.
The set screw that comes with the bracket wasn't long enough to hold the clam shells so I bought a 1/4"x1" set screw and lock nut to hold it tight. The set screw tightens against the top clamshell and does not pinch the plastic cable or interfere with wire cable movement.
Any adjustments are quick and cover any 4150-style carb setup I choose. Easy to adjust for WOT in any position.
I also fabbed a small L-shaped bracket to mount underneath for the double return springs.
(Once the L-88 style hood was reinstalled, I removed the 1" carb spacer because of height issues, used a 1/2" spacer instead.)
This involved some extra work but I enjoy coming up with something clean and effective. This solution works for me and maybe it can help someone else looking to use the factory accelerator cable and CSR style bracket on a Edelbrock Air-Gap.
Good luck.
Old May 11, 2011 | 10:04 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
ZIP has it as well. $32.50
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old May 12, 2011 | 06:32 AM
boltnut's Avatar
boltnut
Originally Posted by dosoctaves
anyone have a pic of that bracket mounted ?
To throttle cable bracket for performer airgap
