My left rear wheel bearing has gone out on my 1981 Corvette. A local mechanic has told me that its better to buy a new complete axel (wheel) assembly instead of buying a new wheel bearing (also said there was 2 of them-and inner and outer?) because it would be very labor intensive to replace just the wheel bearing. Is this guy blowing smoke up my shorts, or do I really need to spend $400 plus to replace the wheel bearing? Any and all comments/thoughts are greatly appreciated!
Thanks, Matthew
A lot depends on how badly your existing assembly is damaged. Most are repairable. Complete, rebuilt trailing arms are available for less than $400 I think.
Do you know how hard it would be to replace the wheel bearing? A good buddy of mine owns a shop, so I would have a shop that I could do it at, but are there certain tools that I would need for such a project?
C2/C3 rear bearings are unique in configuration and unlike any other car that your buddy probably knows, or have proper assembly or set up tools for. You don't want him 'learning' on yours or trying to improvise by using tools on hand.
The end play/clearance of the bearings is critical to good reliability and longevity.
Its extremely difficult if you have no experience with them. You need about $500 worth of special service tools and a good knowledge of mechanics in general, and there is still a big learning curve because they are unlike any other car I have ever seen. Don't expect the average mechanic to have a clue. Also, if they aren't done exactly right, they won't last. Got you scared yet?
If you have a lot of mechanical aptitude, access to a complete shop, don't mind buying some special tools, and are a hands on type of guy, and have better than average mechanical aptitiude, you can do it. Otherwise pull the entire trailing arm and send it off to someone who does them all the time. You'll be much better off.
If someone told you $400 installed on the car they either didn't know what they were talking about or they're doing you a huge favor. You're best off parking the car until you can obtain a set of rebuilt trailing arms; there are many vendors out there so just shop around for the best deal. Also, unless you're a fairly competent mechanic the job of swapping out the trailing arm assemblies can be easily over one's head. Keep us on the forum posted and you'll get lots of good advice.
I just did both of mine by myself and it was one of the more difficult and time consuming things I've done so far (except the rear wheel well carpets). If they die on me, I'm having them done by someone else while I sit in my pool and drink beer. It was a good experience, but not my favorite.
1. Call VanSteel (Tell them you're a Forum member for 10% off)
2. Wait on UPS to deliver them
3. Bolt them on.
4. Drive the car- and you won't have ever worry about the rear wheel bearings again.
