cyl compr test.
Old Apr 20, 2002 | 07:42 AM
WESCH's Avatar
WESCH
Default cyl compr test.
Hi
You might remember my saga about the broken engine head rockers.
2 ea intake and one exhaust rocker just broke like glass after having them in for less than 500 Miles.
I didn't worry about the intake rockers as this should not harm the engine not getting air to fill the piston, but the exhaust rocker was very noisy as the burned gas had no way out except through the piston rings or back into the carb. :mad
So I did a compression check on all pistons, what do you think ?
I hope that the difference is from the old original L71 heads, no work has been done to them so far.
Oh, it's a 427 11.5 compr engine.
All in all, they push pretty high ( 11 + Bar ), don't they ?
I used a push on tester, not a screw on type, so slight losses might have occured.
Gunther
[Modified by WESCH, 5:43 AM 4/20/2002]
Old Apr 20, 2002 | 09:55 AM
Matt Gruber's Avatar
Matt Gruber
Default Re: cyl compr test. (WESCH)
in the US a bar is a place to meet girls, or get drunk.
We use PSI pounds per square inch
Old Apr 20, 2002 | 04:17 PM
Paul L's Avatar
Paul L
A bar is 14.5 pounds per square inch (psi). So you are peaking at about 150-160psi in each cylinder consistent one to the other. I will leave it to the engine experts - I have never seen this type of chart before - to interpret but that looks pretty fine to me.
[Modified by paul79, 3:26 PM 4/20/2002]
Old Apr 20, 2002 | 04:25 PM
One GM A Tech's Avatar
One GM A Tech
considering the push on type tester u are in the money. What you are lookin for is uniformity form cylinder to cylinder. what should do is a leak down test that is a better barometer for internal engine health and can point out your trouble spots ,,,good luck with it :cool: :seeya
Old Apr 20, 2002 | 04:54 PM
WESCH's Avatar
WESCH
Default Re: cyl compr test. (One GM A Tech)
Thanks.
What I was looking for is damage to the piston rings, valve seat or any major other fault, this caused by the failing exhaust rocker. I was afraight about the hot burned gas not finding a way out through the correct way. ( exhaust valve into exhaust , as the valve stayed closed ).
It looks like if nothing major has happened ?
How much difference between cyl press is considered still healthy ?
Thanks Paul79 to help me on this Bar issue.
Your correct, 1 Bar is 14,50377 pounds/inch2 , so 11 Bar is about 160 PSI.
Over here in Europe, we do use metrical units ( not feed , arms or legs )
:lol:
Anyway, I'm working in the airline business, and our company operates B747-400 , so I'm also used to your units. :D
Thanks a lot. Gunther :seeya
Old Apr 20, 2002 | 05:00 PM
One GM A Tech
excellent would be within 10% and average is 20% and dont forget to change the oil if it was running like that for a while :chevy :seeya
To cyl compr test.
