`1979 Cruise issue...
Old May 9, 2011 | 09:38 PM
toyvet1's Avatar
toyvet1
Default `1979 Cruise issue...
I have a 1979 the the cruise control seems to let the speed float. It will float between 5 mph of what is set for. It normallt drops about 5 mph when set then recover to the set speed and continue the cycle. It is really smppth and if you didnt look at the speedo you wouldnt know it was happening.
Both cables are brand new and the transducer is about 3 years old. The speedo needle is smooth from 0 to XXX so i dont think the cables are the issue.
Is there any adjustments on the transducer that might correct this , Ivwe already worked with the orfice coming out the side of the transduce and dont get results.
Old May 9, 2011 | 11:11 PM
drwet's Avatar
drwet
I think there is an adjustment for that on the cruise control unit. I adjusted mine many years ago and solved the same problem. The information is in the factory service manual. I don't remember the details. Check your service manual. Its in there.
Old May 10, 2011 | 07:20 AM
79L48's Avatar
79L48
There is a rod that can be adjusted at the transducer and there is some fine adjustment at the unit itself. There are several pages on it in the GM shop manual.
To `1979 Cruise issue...
