200r4 tranny
Old May 10, 2011 | 01:08 AM
Ralphbf's Avatar
Ralphbf
Default 200r4 tranny
Will this bolt into my 1975 Corvette?
200r4 transmission out of a 1986 Buick Regal V-8.
I've done some research and it looks pretty good so far.
I know I need to do something about the lock up converter electrically.
And the Transmission support.
But is this what I'm looking for?
I'm probably putting out less than 300hp.
Ralph
Old May 10, 2011 | 10:08 AM
CTVETTE78's Avatar
CTVETTE78
You're on the right track. The 2004R will bolt up to your engine, and you can also use the stock cross member. If your trans is in otherwise good condition, I would install a Transgo shift kit as a minimum.
ffvetteman's Avatar
ffvetteman
I put a 2004R in a 77. I used the stock crossmember but I had to do some small grinding near the trans mount to let it clear. Or Bowtie overdrives sells a tubular crossmember for it. Is the 86 trans electronically controlled? I'm not a transmission expert but does the tv cable control the lockup? I thought they were not electronically controlled until the early 90's.
Old May 10, 2011 | 10:27 AM
CTVETTE78's Avatar
CTVETTE78
2004R's are not electronically controlled, but do use an electrical signal from a remote switch to lock up the TC. The TV cable does not control the lock-up.
There is a lot of very good information on these transmissions on the turbo Buick sites, and Bow Tie Overdrives has good info on their site as well.
Old May 10, 2011 | 10:46 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
you can do a search on 200r4 swap on here and you will get a ton of good info... I even have a thread started with some doon info some place on here...
http://forums.corvetteforum.com/c3-g...n-my-77-a.html
To 200r4 tranny
