Rear camber question
Old May 10, 2011 | 03:24 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Default Rear camber question
I am out of adjustment on my left rear strut rod and still can't get correct camber setting. Will adjustable struts give me more range of adjustment? Original strut was bent, I just thought someone hjt something. Now I'm not so sure. Is that how they bubba'd it in the day? Thanks
Old May 10, 2011 | 05:16 PM
'75's Avatar
'75
One of the things that affect rear camber is the diff side yokes. If they are worn on the inside end, you will have too much negative camber.
Old May 10, 2011 | 05:22 PM
wcsinx's Avatar
wcsinx
not uncommon for bubba to bend the strut rods for more positive camber
I'm assuming you're out of negative adjustment?
Old May 10, 2011 | 06:25 PM
Mick71's Avatar
Mick71
Looking from the rear, top of tire is tilted in. All new parts. Started with low mi. (15k) car, yokes looked good when I put new u-joints in.
Old May 10, 2011 | 08:29 PM
wcsinx's Avatar
wcsinx
Tilted in is negative camber. You prob. have worn out stub axles causing that, and bubba tried to correct it bending (shortening) your strut rods.
Old May 10, 2011 | 08:39 PM
Mick71's Avatar
Mick71
All brand new wheel bearings, set up with correct end play and torqued to spec. New trailing arm bushings, new Moog strut rods, everything. I'm stumped..
Old May 10, 2011 | 08:46 PM
zwede's Avatar
zwede
With car on jacks grab wheel at 12 &6 and wiggle. I think you'll see the diff stub axle move in/outof the diff case indicating it's worn out .
Old May 10, 2011 | 08:55 PM
wcsinx's Avatar
wcsinx
So you replaced everything but the stub axles, ehh?
Old May 10, 2011 | 09:32 PM
drwet's Avatar
drwet
Very common problem. You need new differential output yokes, stub shafts, whatever you call them, they're wore out!
Old May 10, 2011 | 09:39 PM
Mick71's Avatar
Mick71
Doh! Will check it out. Thanks guys.
Old May 11, 2011 | 12:07 AM
Solid LT1's Avatar
Solid LT1
I find the differential cross shaft usually wears at a faster rate than a side yoke but, what do I know
Are you trailing arms centered in the pockets? I find the range of camber adjustment on a C3 Vette to be pretty far if all components/frame are not crash damaged.
If you find your cross shaft worn, Tom's Differentials has a good hardened one for sale, better than GM part sold in today's world.
Old May 11, 2011 | 03:15 PM
Surfer69's Avatar
Surfer69
I just went through this.
Even with new diff, yokes and bushings and stock struts, I was just barely making it which didnt make sense. Couldnt figure out why.
No question adjustables would solve this problem. my.02
Old May 11, 2011 | 05:23 PM
Mick71's Avatar
Mick71
My trailing arms are centered in the pockets, and did the 6 and 12 check and it seems all good. Didn't pull the halfshafts yet, but everything seems good and tight. Didn't see any play where yoke goes into diff.
Old May 12, 2011 | 04:54 PM
redstingray74's Avatar
redstingray74
Just a quick note , The stout adjustable rods I got with urethane bushings I got from
Mid-America vette are excellent in my 74 L-82 best value I've seen for under 100.00 on sale. Very easy install. Easy to work with instead of old factory rods . Changed the whole
personality of handling . I love em.
Old May 12, 2011 | 05:01 PM
Mick71's Avatar
Mick71
Gonna give them a try for sure. Thank you for your input
To Rear camber question
