Fast Idle and Engine Run on
Old May 10, 2011 | 05:31 PM
Berniep92's Avatar
Berniep92
5th Gear
Default Fast Idle and Engine Run on
I recently changed my Manifold and Carburator on my 1975 Stingray. I have two issues. First I can't seem to get the engine idle to get down below 7k. I have adjusted the idle screw on my Eddlebrock carb, it helped a little but still seems fast. My second problem is that when I shut the car off, it will continue to run for a few seconds. Could this be a timing problem? any suggestions as to what to look at would be greatly appreciated.
Old May 10, 2011 | 05:48 PM
sly vette's Avatar
sly vette
Sounds like you may have a substantial vac. leak. Or something preventing the throttle linkage from returning all the way. Has there been any eng. work done recently???
Old May 10, 2011 | 05:49 PM
h2ohouse's Avatar
h2ohouse
No expert, but I did the same. Changed to a new edlebrock 1405 (with electric choke). The car will run a little after shut off if your idle is too high. My timing is advanced 8 degrees and when idleing properly at 7 it will shut down fine. My idle is actually irratic...so I was going to check for a vacuum leak...maybe you should try that first.
To Fast Idle and Engine Run on
