need a quick answer- m22 in an 81 model?
thank you
That's not saying someone couldn't bolt one right in but I'd say the chances of it being a real M-22 are slim.
Seems like everyone thinks they've got the famous M-22 but most people can't tell the difference between it or any other Muncie.
I'm not sure but I think the 81 came with the Borg Warner T-10.
The last year to use a Muncie was 74, from 75 through 81, all Corvettes had BW Super T-10s.
Again, thanks for the info on such a short notice.
From 63-65, all GM 4 speeds carried the RPO M20. Certain horse powers got the close-ratio, and others got the wide-ratio. It made no difference if it was an early 63 with a BW T-10, or a late 63-65 Muncie, they all were M20's.
GM first offered the M22 in 66, and changed the RPOs. From 66 on, M20 was the wide-ratio, M21 indicated the close-ratio and M22 was the RPO for the "Heavy-Duty" 4 speed. These RPOs continued to be used from 66 to 79. 80-81 4 speeds were RPO M18.
The hobby has adopted M20, M21 & M22 to designate Muncies, but to GM, these RPOs only designated the type of trans.
An M20 can be a T-10, a Muncie, a Super T-10 or a 78-79 Saginaw. M21's can be a Muncie or a Super T-10, while the only M22 made came from Muncie.
if it is a muncie then it can be anything since it cannot be original.
if it is a super t-10, then it 'might' be original. but not a M22
if the seller is stating it is an original to the car muncie, then assume he is incorrect in the description of the other details of the car.
