427 head gaskets
Old May 12, 2011 | 07:27 PM
Corvette Kiwi's Avatar
Corvette Kiwi
Default 427 head gaskets
Does anyone know the specs of the stock/original head gaskets used on a 1969 Corvette L-71 V-8 (427 c.i., 435 hp, 3x2 carbs)?
1. Steel shim, composite, or ??
2. Head gasket thickness of ??
3. Bore size (often times head gaskets have a slightly larger opening that the bore itself ... but how much larger was the stock gasket)
Old May 12, 2011 | 09:39 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
IIRC, they were 0.022" steel shims, and "recommended for 4.250" bores", which doesn't answer part B of your question. FWIW, a .020" x 4.370" gasket will theoretically bump CR up by only 0.022:1 in comparison to an actual .022" x 4.250" one. Wouldn't loose any sleep worrying about running 4.37's on a 427. Rather I highly suggest choosing gasket thickness based on quench math over what might be original. Do you know your piston to deck heights?
