oil pan
also what is the best oil to run I used a stock spec 350hp cam with flat lifters and roler rockers
Thanks in advance for your help
http://forums.corvetteforum.com/c3-p...-68-parts.html
shmoky
http://www.summitracing.com/parts/MOR-20170/
Disconnect the battery,Drain the oil and remove oil filter,
Drop the starter,
Remove the transmission cover plate,
Drop the steering cylinder,
Drop the idler arm,
Remove the oil pan bolts,
Clean the engine were the new seal will go,
Use a one piece seal for 79 corvette 350,
Check oil pump inlet for popper depth to new oil pan,
Install new seal with sealant in the corners only,
Install pan,
Install steering cylinder,
Install idler arm,
Install transmission access cover,
Install starter,
Fill with new oil and new oil filter,
Connect battery,
Did I mention to Disconnect the Battery, the Starter is very Hot!
thanks so much for your help
