Power steering cylinder line question
May 14, 2011 | 12:47 PM
OK, all my books are packed up and I should have marked them, but just check me here to see if I'm correct,
The line with the larger of the two metal loops goes from the top fitting of the control valve to the lower fitting on the slave cylinder.
So the smaller metal loop line goes from the bottom fitting on the control valve to the top fitting on the slave cylinder?
Also, is that shield on the control valve needed, it doesn't seem to be protecting much.
Thanks,
Frank
May 14, 2011 | 11:35 PM
ttt for my Sunday project
thanks,
Frank
May 15, 2011 | 02:36 AM
Yes. Assuming your P/S components are oriented correctly, the hoses cross over each other when they are installed.
May 15, 2011 | 07:52 AM
From the '77 AIM. Top hose on the cylinder goes to the bottom on the control valve. The shield/bracket helps locate the hoses at the valve. mike...
May 15, 2011 | 03:35 PM
GREAT -
Thanks for the help, and the photo, my AIM is packed up somewhere.
I'm finally on it and headed out to get it done,
I appreciate it,
Frank
May 15, 2011 | 10:24 PM
Thanks guys - I got done today,
The lines fit exactly like the AIM shows,
Thanks again,
Frank
May 16, 2011 | 07:17 AM
MDS3013 is correct. The bolted-on bracket has two bent ears that are to be used to locate the two cylinder lines. The hoses should be located to just touch the bracket.
Jim
1977 ,
77 ,
c3 ,
control ,
corvette ,
cylinder ,
diagram ,
line ,
locations ,
power ,
replaced ,
slave ,
steering ,
valve
