Need Help with my lights
Old May 14, 2011 | 09:46 PM
pncaldwell82's Avatar
pncaldwell82
1st Gear
Default Need Help with my lights
Whats up guys I am new to this form. I have a 75 stingray and I am having issues with my lights staying opened. I think I messed them up but any Ideas would be appreciated. Basically whats going on is I manually opened my lights by pushing them up from under the car while it was off. But now my head lights stay open all the time. I have crawled under my car and manually closed my lights but when ever I start up my car they open up automatically. There is no change If I have the headlight switch on or off. They worked perfect until I opened them by hand. Is it possible That I got them out of timing or stroke???? I don't know much about the headlight system. Any suggestions???????
Thanks, Pete
Old May 14, 2011 | 11:15 PM
wombvette's Avatar
wombvette
Thanks, Pete
No damage should occur by moving them manually. Check the small signal hose. When that hose is removed it will cause the HL to stay up. You probably knocked that off.
Old May 15, 2011 | 08:53 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The black and white stripped hose in the picture.
Old May 15, 2011 | 10:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the over ride switch under the steering column.
Old May 15, 2011 | 11:15 AM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
Old May 15, 2011 | 11:29 AM
pncaldwell82
1st Gear
wow I feel like a complete . turns out it was the over ride switch under the steering column. Thanks for the help guys
Old May 15, 2011 | 03:17 PM
0Willcox Corvette
Former Vendor
Glad your fixed now.s. but don't feel alone.. it happens all the time.
To Need Help with my lights
