T%*!ing Rear-End?
Old Apr 20, 2002 | 09:25 PM
Midyrman's Avatar
Midyrman
Default T%*!ing Rear-End?
After running my '70 conv. for several (5-10) miles (and it is warmed up)and I stop and back up I hear a thumping noise coming from the rear area of the car. The noise sounds like something is grabing and releasing... not in perfect cadence--it is randon in both frequency and loudness but repeats every second or two. Seems to be more prevelant when I attempt to steer the car one way or the other. When cold, it does not do this.
Could this be the rear-end posi clutches?
Could this be the u-joint from drive shaft to rear end- which looks very dry (and original to the car).
Any help would greatly be appreciated.
Thanks. Tom
Old Apr 20, 2002 | 09:42 PM
GTR1999's Avatar
GTR1999
Default Re: T%*!ing Rear-End? (Midyrman)
Most times it's the clutches slipping. Try draining the rear oil and adding the GM additive and GM oil. SOme guys use Redline or Amsoil but I always used the GM stuff. Lucas oil 85-140 was also recommended. Do some figure "8"'s in a lot after you fill it so the oil gets into the clutches.
Gary
