Head light switch connection block
Old May 16, 2011 | 12:28 PM
JWags's Avatar
JWags
7th Gear
Default Head light switch connection block
Does anyone have photo of connection block for the 1978 head light switch? I replace the orginal block because due to typical melting around the terminals. I made a drawing and color route on orginal but when the replacement pig tail came in the wire colors were different not really an issue since I only needed the block the problem came when I installed the new switch I keep blowing the taillight fuse when I turned on the switch. I found the terminals on the switch did not match the
the block. Any thoughts?
