600 Holley -- pump to carb fuel line question.
if the gas filter was above the level of the gas in the tank you wouldn't have a problem. Put the filter in the correct location above the fuel level in the tank. Other than between the frame and the pump you should not have a 7" long rubber line.
Hmm I know what u mean maybe it was easy for whoever made that set up but I'm not sure about if its not gonna leak above it when the tank is full I can use a long line to test it out I ll also post a picture of the current line and let u know but I think the whole system is not safe again cause if something happens to fuel line all the way from pump to engine bay .the distance is too far without a valve that s my thinking
I can't count the number of hot rods I've seen done this way without mishap. Even factories do it; my '82 has factory rubber hose at both ends of the frame-mounted fuel filter, less than a foot from the CAT. I don't care for the OP's filter hanging in the air at the midpoint, but other than that, it should be fine. Just be sure to inspect the hose occasionally and maybe replace it as a matter of routine every two or three years.
Pump to engine bay?
Well as I said I just bought the car and have not checked the original set up yet but the owner told me it is replaced with an electric pump that's right
Gravity
To solve your problem, you have to raise the front of the car before removing your rubber fuel line at the fuel pump. Raise it high enough that the end of the steel line on the chassis is higher than your fuel tank.
Some ramps or a large truck jack (with supports added before getting under the car!!!) should do the job.
Regards from Down Under.
aussiejohn
A different fuel bowl?
[QUOTE=1976 corvette;1577634720]Off one of my part’s cars I came across a not bad looking holly 600 hidden below the air cleaner so I decided to install it on my 76 driver. It sits fine on a 2101 intake manifolds but I didn’t like how I ran the gas line. I just copied how it was on my parts car and even used the same cut metal gas line but I do not like the idea of having the most flammable thing in a car that closes to the hottest thing in a vehicle with only rubber in between. The fuel filter touches up against the coolant goose neck and the intake manifold so that can't be good. I can’t be the first one to do this, so what has everyone else done? Any ideas would be greatly appreciated? Thanks
I'm no expert on Holley carbs, but have you considered trying to find out if Holley makes a front fuel bowl that has its inlet on the passenger side? If so, then that would solve the problem of running a fuel line across the front of the carb and your inlet would then be on the same side as the pump and you should be able to buy or have made a one piece steel line from pump to carb.
aussiejohn
aussiejohn
Well obviously they preferred to keep the rubber line away from engine. the location does not matter to me and it seems preety safe there but does the gas keep coming on your system when u unplug the rubber line ? That's the point that I don't feel very safe with . thank u for answering.
IT's not that tough to bend a steel line and flare (either AN or Inverted flare) to connect the carb and pump. It'll take a few attempts to get it perfect, but it's worth the effort. I use 3/8 brake tube. If you get real industrious, you can polish it up a bit and clear coat it.
And as noted by 7T1- a rubber hose is going to leak sooner or later. Even the big buck braided hoses will leak sometime. And the fuel will not necessarily come out of the hose at the leak.
#33
just so you know, you can get high pressure fuel line that works just fine. my '95 has rubber line from the factory at the tank on the high pressure side and it is under much more pressure than that stock fuel pump. replacement line is yellow and is perfectly safe.
however, buying a straight piece of line and bending it to fit is really not that hard. if you stick with flexible line, don't just clamp on the steel, you can make a swage or a bead on the end so it acts like a barb. and I would get rid of that filter, they are known to be poor, or at least put it lower closer to the pump instead of up there where it will sit with an air bubble all he time.
and yes Fords used rubber from the line to the filter all the time, so did some Chrysler. new fuel filters used to come with 2 short 3" pieces for each end with a couple spring clamps...
#34
You still havent fully explained or provided a picture of your fuel system.
You told us you have an electric pump but have not mentioned if it is located in the rear of the car which is where I assume it is.
You have not told us whether the stock mechanical pump is still on the car?
If the stock mechanical pump is still on the car is it connected so that fuel from the electric pump runs through it?
Exactly what two components is this 7" length of rubber hose connecting?
#35
From summit you can buy a Holley carb fuel inlet line with filter (the chrome bit). Then I bent a hardline from the filter to the fuel pump (mechanical)
Nick
Nick
#36
Your engine backfires and pukes fuel and spark on the foam open top air filter element which catches fire and in turn melts your hood and if not caught in time burns the front of the car off
Seen it happen.
#37
i have also witness this .happen so fast car was destroyed even with best efforts from nearby portable fire equipment.
#40
which is why I keep saying all threads should be locked automatically if they have had no new posts within a year or something...
