Is a T5 a Tremec? I lose track of all the acronyms somedays. Even if your rear ratio is higher numerically, I would say yes, good combo. The 3.70's should be fine when used with tires that are near stock height, 26.9" - 27" tall.
Any trans that has overdrive has to help highway cruising, both in terms of less engine rpms and greater satisfaction of enjoying the car more often.
There are a few folks here who have installed the T5. I'm seriously considering it as a replacement for the stock 4 speed.
Just make sure you get a T5 that was designed for and was behind a V8 and not the V6 version. Tougher to find the GM V8 version but can be found in the $500-$800 range.
I just got this info from the seller.
Gear:
1 2 3 4 5
3.35:1 1.99:1 1.33:1 1.00:1 0.68:1
Can it be this tranni:
Mustang
Introduced in ’83, the T-5 arguably gained its fame in the Mustang 5.0. The first to take the step up to WC in ’85, Ford used the T-5 through the Fox-body & SN-95 chassis ending in ’95. The strongest T-5 available was found in later Mustangs and available through Ford’s Motorsport & SVO operations.
Available with a few different gearsets, the most common gearing was from ’85 through ’95:
