5spd OD gearbox ratio question
Im wery interesting in getting inputs, not only of the good things with these boxes but also the bad or/and problematic things.
Since i dont do dragracing with large rear tyres and prefer using the car on ordinary roads and occationally trackdays i would like a box with a high (numreric low) 1st gear.
Today i have the M20 with a 2,52 first gear and that one is a little bit to "short" when going down on first in for exaple a cicane.
For me an optimal solution would be a M22 with its 2,20 first gear and with "close ratio" first four gears (1-1 on 4th gear) togheter with a overdrive 5th gear.
Does a gerbox like that exist?
The TKO i have seen has 2,87 first gear wich is even lower than my old M20.
The Richmond 6spd i have seen has a 3.28 first gear wich will propably be good for large DR slicks.
Since im running a 454 i dont think acually need 6 gears..
Inputs or ideas?
//Ricky.
I feel that the OD ratio on the 5th are OK ither way since it only will be used as a highway cruise overdrive.
FWIW, the Richmond SS 5-speed w/OD is available with 2.89:1 1st and 0.77 5th. By comparison, the TKO 600's 0.64 5th is going to yield you a very tall 2.15:1 final ratio, while the 600-RR version's 0.82 a 2.76 top.
Unless you've massive top end power, your terminal velocity will be a bit lower than such ratios might seem to suggest, but don't assume the tallest possible combination will necessarily equate to the best economy in cruise mode.
No i dont have "massive top end power".
The engine is a mild but solid 454 with a hydraulic roller that puts out 462hp on 5500rpm.
If i take it flat out on the 5th gear with a Richm or TKO (overdrive) the topspeed will be way more than i need (im getting old and like to live).
But the overdrive will make the car more usable and i hope i can catch up with the newer cars on normal highway driving.
It will give me an 18% reduction of rpm:s on the highway.
I got the feeling that the 0,64 may be rediculous high for my use.
Anyone that runs 3,36 final gear that would like to sheare there experiences of ther OD:s with me?
I guess that there are no 5spd overdrive box with a 2,20 (or close) first gear?
the 064 would be too tall although some would argue that
2600 rpm is 75 mph with mine in 5th and i have good get up at that speed also which was important in my decision
i also have a 454ho crate and like you i wish low gear were a little taller but the 287 is not all that bad either...good luck.....
ps...tires are 235 15 70's on the rear
I run 255/60/15 on all four on my ralleywheels and they stays on for the road driving.
Acording to the "Hurst Driveline RPM Calculator" those tyres together with the 3,36 rearend will give me a cruising rpm at 75 mph of 2600rpm.
I found a setup wich gives me the following ratios.
1st = 3,28
2nd = 2,14
3rd = 1,57
4th = 1,24
5th = 1,00
6th = 0,76
This will give me a very usefull second gear and a low 1st, a nice 1,0 on 5th and a good overdrive on 6th.
However, there is a lot of gears..
Anyone got a 6spd in his car?
How is it to shift?
I've driven a 2.20 first gear before M tranny and taking off is not very good
1st 2.97
2nd 2.07
3rd 1.43
4th 1.00
5th .84
6th .57
I am running a 3.70 rear. I like the gear spread over the TKO 500 I was running. 5th gear is more useable and you don't get the big rpm drop. 6th gear is definitly a highway gear for 65+ mph. 3000 rpm in 6th nets you 110 mph.
2000 rpm is about 74 mph. 1st 4 gears are excellent for acceleration and 5th and 6th are good for cruising the roads. The T56 is no picnic to get into a C3 though but it can be done. It is big and heavy but it shifts very slick and the gate is very tight.
1st 2.97
2nd 2.07
3rd 1.43
4th 1.00
5th .84
6th .57
Im a bit afraid that its easy to get it in wrong gear when "speedshifting" (comparing with my 4spd).
Is that a problem or do you get used to it?
Yea the 2,20 is not for fast launching..
Maybe the 6spd Richmond a mentioned abowe is a good one then, With that one i get both the "launch-gear" and a usable second gear for tight corners..
Does the T56 has an ordernary "outside" lincage for the shifter or is it "internal" as for the TKO?
Look here for a picture of it. It is big.
http://ultimategto.com/cgi-bin/showc...005/05_00084_2
First thing you should know is that the trans is available with about a have dozen choices for 1st and 6th gear. You might try one with a 2.77 or 3.04 1st. 6th will depend on your engines torque and how much hiway cruising you do. But the list is here:
http://www.richmondgear.com/07pdfs/RG21.pdf
It shifts a little notchier compared to an internal shift, but is much better than the old Muncie shifter.
Other advantages, you keep yor bell housing clutch, Z bar linkage, driveshaft, shifter location. If you buy the 67 hurst 4 speed shifter, it even looks like the old Muncie from inside the car.
The only mod was to the trans mount, it has to be a little lower.
Pic from inside the car.
1st = 3,28
2nd = 2,14
3rd = 1,57
4th = 1,24
5th = 1,00
6th = 0,76
How is it to shift?
So with the Richmond i basically can chose any gearing i want at 1st gear!
That sounds just fine to me.
//Ricky.
