Water Pump Question
Old May 18, 2011 | 11:03 PM
colt61's Avatar
colt61
8th Gear
Default Water Pump Question
I understand the vette short pump with the 3/4" inch pilot issue, but are there any clearance issues with a long pump and changing to the new brackets/pulleys and using a Dewitts rad/fan combo? Thanks in advance!!
Old May 19, 2011 | 01:14 AM
trw's Avatar
trw
Why not just buy an aftermarket pump that fits?
It would be easier than all the bracket changes.
I picked an aluminum one up on fleabay for about $50.
Hope this helps.
Old May 19, 2011 | 06:47 AM
wydglydrydr's Avatar
wydglydrydr
I put a serpentine system in my car, so I now have a long pump. I've got a DeWitt's rad with dual SPAL, and plenty of room in between everything. If the DeWitt's combo is the way you intend to go, using a long pump won't be an issue.
Old May 19, 2011 | 08:25 AM
colt61's Avatar
colt61
8th Gear
Thank You, that was what I was looking for. Its a ZZ383 and buying brackets and pulleys anyway, hated the idea of doing the pump also. Thanks to both for the quick responses.
To Water Pump Question
