Points to hei conversion double check
Old May 19, 2011 | 12:19 PM
boltnut's Avatar
boltnut
Default Points to hei conversion double check
The previous owner swapped the points out of the OE distributor with a pertronix kit. I am trying to make sure he did it right.
What color is the original resistance wire in a 73 ? Pink ?
Does the entire wire back to the fuse block need to be replaced ?
The condenser/capacitor is still mounted to the coil, do I need this ?
What symptoms would the wrong supply wire give me ?
What would that condenser be doing now ?
Old May 19, 2011 | 12:38 PM
MelWff's Avatar
MelWff
these are the instruction for the petronix unit, you need a 12V source, typically there is an empty spot on fuse block where you can run the wire
http://www.pertronix.com/support/man...itor12vneg.pdf
The condenser on the coil is for radio interference
Old May 19, 2011 | 12:52 PM
Mike Ward's Avatar
Mike Ward
The pertronix kit or anything similar is not HEI. It simply replaces the mechanical points with an electrical switch. Big difference.
Old May 19, 2011 | 01:01 PM
boltnut's Avatar
boltnut
ok. i have not personally done this conversion. i am now understanding the unit. thanks guys.
Old May 19, 2011 | 02:57 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Thank you!
It's been a pet peeve of mine to hear the label HEI thrown around to describe anything that doesn't have points. As you correctly stated there is a big difference.
Again,
To Points to hei conversion double check
