Oil Pan Question
Old May 19, 2011 | 05:19 PM
68/BB's Avatar
68/BB
Default Oil Pan Question
I built my 468 with a Chevelle oil pan. Will this fit in a 68 Vette or will I need a Vette only pan? If so what is the part number?
Old May 20, 2011 | 11:21 AM
MelWff's Avatar
MelWff
This is the part number in the current addition of the General Motors Performance parts catalog
14091356
Corvette Oil Pan (1965-1974)
• 5-quart pan has a trap door baffle that controls oil slosh during
cornering and heavy braking
• Windage tray is included and requires four mounting studs,
P/N 3902885
• Used on LS7 engine assembly P/N 3965774
NOTE: Use the following part numbers for the oil pan rails:
P/N 3860048 (x2), 3860049 (x1), and 3860050 (x1). Parts are
available through Vintage Parts.
Old May 20, 2011 | 01:37 PM
hugie82's Avatar
hugie82
I used the stock oilpan from a BBC Impala that fit in a 76 Monte Carlo and then it found its way into a 74 Vette. I would use it
Old May 20, 2011 | 01:53 PM
Rebelrob's Avatar
Rebelrob
Looks just like my Oil Pan which is an LS7 Block. It fits fine.
To Oil Pan Question
