Dead Battery - Any good debugging processes?
Old Apr 21, 2002 | 01:24 PM
pingdashf's Avatar
pingdashf
Default Dead Battery - Any good debugging processes?
My battery dies. And I mean, DIES. No juice left, to the point jumping wont work it and it has to be recharged for hours upon hours or even replaced.
I know nothing about the electrical system, so this should be an adventure. I know there is something called an alternator somewhere that can cause this, but how to do I find out if it is the alternator? and if its not the alternator what could it be? I'm going to lookup what an alternator is now.... Thanks for helping me out if you can...
Old Apr 21, 2002 | 01:37 PM
rdrman's Avatar
rdrman
Default Re: Dead Battery - Any good debugging processes? (pingdashf)
Do you have a volt meter or a multimeter? If not one can be purchased at any electronic store or home supply store. This you will need to track down your problem. The good thing is that it will pay for itself 10X over.
Old Apr 21, 2002 | 01:46 PM
pingdashf's Avatar
pingdashf
Default Re: Dead Battery - Any good debugging processes? (rdrman)
I do have a volt meter/multi-meter somewhere. If not I will certainly buy one. I know they are invaluable for this kind of work.
Old Apr 21, 2002 | 03:01 PM
Bills17n72's Avatar
Bills17n72
Hey does your car have the lights that stay on 90 seconds after you leave your car,if so it could be the delay timer .
yo Bill
Old Apr 21, 2002 | 03:06 PM
73-454's Avatar
73-454
Real easy to teast your battery 1) charge the battery for at least one hour a charger with a 5 to 15 amp output will be more then enough. 2) remove charger turn on your headlights for 2 minutes " do not run engine" turn lights off now take a voltage reading at the battery if your battery reads less then 12.50 volts replace the battery. To test the alternator start the vette keep rpms at least 1500 rpm take a voltage reading at the battery if the reading is less then 13.5 volts replace the alternator. Also if you need a new battery the best battery on the market is the GM Delco fredom batter it will outlast your Vette. Good luck
Old Apr 21, 2002 | 09:46 PM
Dave68's Avatar
Dave68
After the battery is fully-charged, does it fail to start the car after just sitting there? If so, then it is a severe drain and I would recommend taking the car to an auto-electric shop for diagnosis.
If the battery is fine just sitting there but will not start after a day of driving, then you may have an alternator/voltage regulator problem. Many auto parts stores will test your electrical system (batter and alternator) for free.
If the battery does not accept a charge, even after many hours, then the battery needs to be replaced.
Good luck!
To Dead Battery - Any good debugging processes?
