Removing Emissions
Old Apr 21, 2002 | 02:04 PM
Justin79-L-82's Avatar
Justin79-L-82
Default Removing Emissions
what is all involved in removing all the emissions crap on a 79 vette?? How do you do it and how much more power does it give you?
Old Apr 21, 2002 | 03:18 PM
mrvette's Avatar
mrvette
Default Re: Removing Emissions (Justin79-L-82)
The only way to seriously increase power is bump the cam up in specs, dump the catastrophic converter, go dual exhaust, and change the intake manifold for a non EGR type, go electric choke on a totally rebuilt Q jet carb....
get the HEI totally reworked....
leave rockers/etc alone....heads are not great, but for street use, will do just fine....
the above should get you roughly 80 hp or so...conservatively....depending on the specifics of the cam you could wind up with 350 hp or so....
of course that depends on engine condition also....that's why the 80 hp guesstimate....
GENE
Old Apr 21, 2002 | 09:14 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
As Gene already posted, there are much bigger power gains to be had by adding components than there are by removing some. If emissions laws aren't an issue where you are at and you can legally remove or disable your emissions equipment, you will probably pick up a few horses by doing so but not that many unless it includes a low restriction exhaust system. If you have an L82, which already has a decent cam, you won't see as dramatic an improvement as you would if you have as L48 which has a much milder cam. If I had a stock `79, my first mod would be a freer exhaust and my second mod would be a cam.
Old Apr 21, 2002 | 09:22 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
You forgot headers, boring, shaving heads, and advancing timing. :D
Old Apr 21, 2002 | 09:41 PM
roscoe1's Avatar
roscoe1
Justin,
I'm looking for some emission parts for my 79. Let me know what you are going to do with yours.
Old Apr 21, 2002 | 09:48 PM
Paul L's Avatar
Paul L
When you take everything off, just ship to me in a box. Name a price. I am in Canada. That makes it easier.
To Removing Emissions
