Engine Harness
Old Apr 21, 2002 | 02:18 PM
chrisvette79's Avatar
chrisvette79
Default Engine Harness
Hi guys,
anyone know how the engine harness gets off (engine compartment where itīs mounted to the outer frame of the fuse box). :cheers:
Old Apr 21, 2002 | 02:31 PM
Steve Straus's Avatar
Steve Straus
Default Re: Engine Harness (chrisvette79)
Hi guys,
I assume you mean the bulkhead connector. There should be a hex screw in the center of the connector. Unscrew it and pull the connector apart. It may be a little brittle and corroded, so go slow and be careful. There may be push tabs that you need to unlock on the edges too.
Old Apr 21, 2002 | 02:35 PM
chrisvette79
Default Re: Engine Harness (Steve Straus)
Thanks!!!! :cheers:
To Engine Harness
