Need help brake lights wont work.
Old May 21, 2011 | 11:40 AM
rob-smash77's Avatar
rob-smash77
4th Gear
Default Need help brake lights wont work.
Does the head light switch have anything to do with the brake lights? I think my head light switch is going because the interior lights stay on and the dash light wont work. The brake lights were working and when the dash light quit the brake lights did too. Any help would greatly appreciated. Rob
Old May 21, 2011 | 03:38 PM
Duke94's Avatar
Duke94
Here's an easy to follow wiring diagram. It's for a 78' but yours should be about the same. Can't see any tie in with the headlight switch. You'll need to get your volt meter out and start probing around.
Gary
http://www.corvetteforum.net/c3/tune.../index12.shtml
Old May 22, 2011 | 11:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the fuse for brake and tail lights. Sounds like you blew a fuse.
To Need help brake lights wont work.
