Numbers Missing From Timing Pointer?
Old May 22, 2011 | 11:49 AM
ted13b's Avatar
ted13b
Default Numbers Missing From Timing Pointer?
My stock 77 L48 runs well, but I wanted to check the timing. The pointer is in place, but a heavy coat of paint has obscured the markings. I see the notches, and the deep notch towards the lower end, is the deep notch TDC, or Chevy's suggested ignition timing setting? Thanks in advance!
Old May 22, 2011 | 12:16 PM
mds3013's Avatar
mds3013
My '77 is an L82. Perhaps the pointers are the same. Large notch is 0 degrees. mike...
Old May 22, 2011 | 12:57 PM
ted13b's Avatar
ted13b
That's it. So it look like my base is set at 12 degrees BTDC. Thanks for the quick response.
To Numbers Missing From Timing Pointer?
