Fuel sending Unit OHMs reading
Old May 20, 2011 | 09:22 PM
rodney25's Avatar
rodney25
Default Fuel sending Unit OHMs reading
I have a question. I have about quarter tank of gas and used an ohms meter to read what the fuel sending unit was reporting and the ohms meter was steady. I went to the back of the car and shook it from left to right hard. I then went back and put the ohms meter on the fuel sending unit and the numbers on the meter was bouncing up and down. Is this normal or does the fuel sending unit need to be replaced?
I also noticed the fuel gauge was also bouncing until the fuel in the tank was steady.
Old May 22, 2011 | 12:39 PM
Alan 71's Avatar
Alan 71
Hi r,
I believe IF the float in the tank moves at all, the signal sent to the gauge changes.
But, there must be some sort delay/buffer in the gauge because IT is very slow to respond , and also moves slowly so it's not 'dancing' around as the car goes up and down hills, and hits bumps in the road.
Stick your hand in the tank, move the float up and down and watch what the gauge does.
Regards,
Alan
Old May 22, 2011 | 02:45 PM
fugawi's Avatar
fugawi
Originally Posted by Alan 71
Hi r,
Regards,
Alan
yup, what he said...
Old May 22, 2011 | 03:03 PM
...Roger...'s Avatar
...Roger...
with above.
Rodney post #41 in this thread shows the buffer that keeps the needle from being too bouncy.
http://forums.corvetteforum.com/c3-t...e-bounces.html
To Fuel sending Unit OHMs reading
