79 Brake Light On
Old May 21, 2011 | 05:36 PM
76yellow's Avatar
76yellow
Default 79 Brake Light On
What would cause the brake light to be on if it is not the switch on the e-brake ?
Old May 21, 2011 | 05:41 PM
...Roger...'s Avatar
...Roger...
Combination valve could be turning it on.
Old May 21, 2011 | 06:05 PM
76yellow's Avatar
76yellow
Thanks Roger...Is that the same as the proportioning valve ? Are those the only two things associated with the light ?
Old May 21, 2011 | 06:13 PM
...Roger...
Yes same thing. In general yes thats the only 2,the ign switch also turns it on as a bulb check but I doubt that will be an issue. Unplug the tan at the prop valve,if the light goes out thats the problem.
Old May 21, 2011 | 07:46 PM
76yellow's Avatar
76yellow
Will do...Thanks again
To 79 Brake Light On
