Taking my '69 to the shop on Wednesday for vacuum system work. It is forcast to rain. Is there a way to manually open the wiper door? Seems I read or heard somewhere there is.
Hi 55,
I'll caution about using Mark's method even in a pinch.... if you don't remove the rubber plug, forcing the door open is very hard on the seal in the actuator. At $125, it's not something you want to screw-up if it's not leaking now.
Good Luck!
Regards,
Alan
