Steering leak
Old May 23, 2011 | 02:21 PM
robs68's Avatar
robs68
Default Steering leak
I have a 68 with power steering less than 2000 miles since total restore.The steering has a leak at the control valve at what looks to be a Zerk fitting ,I know its not a Zerk, second one to do this and it sucks.Can it be plug or do I have to keep changing them. I would like to go to a rack but not in the budget at this time. Please help Thanks
Old May 23, 2011 | 02:24 PM
MelWff's Avatar
MelWff
why do to say it's not a zerk, the valve does have a grease fitting, are you saying you have never greased the valve?
Old May 23, 2011 | 02:31 PM
robs68's Avatar
robs68
I would think they would go more than 2000 miles between grease. but where is the oil coming from maybe a bad o-ring
Old May 23, 2011 | 03:05 PM
robs68's Avatar
robs68
I am positive it is coming out of the Zerk.A guy in our clubs is doing the same thing.The link you sent says some have a socket set screw that would stop the problem. I hope this is correct
Old May 23, 2011 | 03:10 PM
7T1vette's Avatar
7T1vette
Once it is greased [internally], you shouldn't need to grease it again. And, many of the 'rebuilt' units have that fitting on the body casting, but it doesn't really get used anymore. If it is really leaking there (and not just running down from somewhere else), you would be best to remove the Zerk fitting and install a pipe plug with the same thread size. Put some plumbing pipe dope on the threads and don't tighten so much that you crack the casting (which can be done with a tapered thread).
Old May 23, 2011 | 03:15 PM
robs68's Avatar
robs68
Thank you for your help!!!!!
Old May 24, 2011 | 01:03 PM
Rally68's Avatar
Rally68
If you have power steering fluid in this area of the valve, you have a bad seal, incorrectly assembled valve, or bad/damaged housing. If you plug the zerk fitting, the fluid will just leak out the ball stud boot. Do a google search for Jim Shea's Steering Papers, go to the Corvette Steering section and scroll down to the control valve papers and read "Control Valve Rebuild Tips." It describes your problem and the common causes, and also contains a cutaway diagram of the valve.
To Steering leak
