Slotted and dimpled rotors
Old May 23, 2011 | 10:41 PM
73ls1's Avatar
73ls1
Default Slotted and dimpled rotors
I replaced my stock rotors with slotted and dimpled rotors .I am sorry I did. The rotors look cool but they make noise.There is a constant swishing coming from the rotors.I put my 73 up on jack stands and you can hear the noise. All the bearings assembly were rebuilt by Van Steel and new u joints were installed.I called the company and they said it was normal. I think I will put my stock rotors back on. Anybody has the same problem? Thanks for your imput,Charlie.
Old May 23, 2011 | 11:13 PM
7T1vette's Avatar
7T1vette
They thought you wanted "gang-buster" brakes....the sound it made was inconsequential. Just curious...was braking really that much better?
Old May 23, 2011 | 11:17 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I might be interested if the price is right since I can't really hear anything over the 427ci. I an a little hesitant though because some things can be very irritating
Pics?
Old May 23, 2011 | 11:36 PM
73ls1's Avatar
73ls1
Default rotors
I can't really tell the difference in braking .It just a case of not asking before buying. I have a new set of stock rotors I might put them on my 73. I will try to post pictures in a couple of days. Charlie
Old May 24, 2011 | 12:22 AM
gkull's Avatar
gkull
U said up on jack stands. Could it be as simple as rotor run out? U might have to shim one side to get the rotor to run true
Old May 24, 2011 | 09:29 PM
shrekviper's Avatar
shrekviper
Slotted and cross-drilled brakes allow off gassing of the brake pads during extreme and prolonged braking. If you're racing, that's good, if not, it's a waste of money...IMHO.
Old May 24, 2011 | 09:40 PM
Gordonm's Avatar
Gordonm
I did it for looks only. I was not expecting any better braking. My rotors were shot so I got them. I have not noticed any noise at all but my car is fairly loud so it would not bother me at all. What pads are you using with them?
Old May 24, 2011 | 09:59 PM
Jack Wood's Avatar
Jack Wood
Default If you were driving it fast enough you wouldn't hear it.
And if you were driving your Corvette like I drive mine, you'd be way too busy to worry about it.
Old May 25, 2011 | 12:35 AM
73ls1's Avatar
73ls1
All my rotors were between .0002 and .0005,so they should be alright.I am running Hawk pads and I used on my stock rotors with no noise. I noticed the noise in town between 35 and 50 mph. I should drive it hard but my wife is my insurance agent.
To Slotted and dimpled rotors
