interior light b attery drain
Old May 24, 2011 | 09:55 AM
pgh red's Avatar
pgh red
Default interior light b attery drain
79 vet interior lights wont go off. checked door switchs seem ok?
pulled out dome and floor bulbs. went back fews days later and battery was completly drained.
i've done a search in forum and there was something about relay switch but it was for a 96 and not sure if my year has one.
how do i go about trouble shooting
thanks in advance
Old May 24, 2011 | 07:01 PM
captl27's Avatar
captl27
I have had problem with the door switches in my 79. One of them looked like it was ok but it had been pushed back in the collar and even though it looked like it worked it was to short to work with the door. I had to unbolt the switch force the inner collar up into the outer collar and crimp it in place. I has worked fine since. I could also be the head light switch is rotated all the way to one side which turns on the interior lights or other more difficult wiring problems. Good luck
Old May 24, 2011 | 07:15 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
thanks in advance
I would pull the fuse.
Old May 25, 2011 | 01:29 AM
gbvette62's Avatar
gbvette62
78-82 Corvettes have a delay timer, that leaves the interior lights on for about 30 seconds, after the doors are closed. I would guess that you have a bad timer.
The timer is located in the dash, to the right of the of the glove box. It's an orange plastic box, approximately 2" square. You should be able to find it by removing the glove box liner.
Once you locate the timer, connect a wire from the timer's ground terminal (the black wire) to a ground to test it, or just by-pass it all together.
To interior light b attery drain
